Maybe this one is the best. It is during import of pictures shot today.
Code: Select all
Error - Unable to load setting created with a later version of Bibble.Code: Select all
exportXMP - XMP Error 102 , Bad XML name
Code: Select all
clFatal: status = -4 "map failed"
Segmentation faultCode: Select all
"9 versions sent to JPEG Full Size batch"
TIFF Error: /home/odd/foto/2017/01/2017-01-02/okh-2017-01-02-16-14-44_1.JPG "Not a TIFF file, bad magic number 55551 (0xd8ff)"
Code: Select all
Segmentation fault
Code: Select all
Container __CATALOG_ROOT__/assets/home/odd/foto/2015/12
throw: VersionAsset::tileStack
terminate called after throwing an instance of 'Berror'
The batch I try to use, is not some strange thing I have made myself, but the standard Aftershot batch, and the only alteration I have done to the file, is sharping, vibrancy and lens correction. Non of them from suspect third part plugins; all standard pre installed functions in Aftershot.
Are we alpha testers and not customers? And not only unpaid apha testers, but a flock who are stupid enough to pay Corel for letting us use months of our time, trying to sort out Corel’s problems?
I am seriously considering a switch to Adobe
By the way: As I wrote this did the batch run, and only two of the files had 0 byte…!
