ASP3.2 Hangs in Batch Processing
Sending groups of processed photos to full-size JPEG in batch mode and the program just hangs after a few (or sometimes dozens). Searched the forums, and I suppose some think it's plug-in usage. I'm typically using zperspector, wavelet sharpen, vigne, and black and white, but I can't seem to find a pattern as to which one might be causing the issue. Any suggestions or links to fixes? My New Year's Resolution may be Lightroom as this is becoming a huge time sink for me...
hannes_hab
- System_Drive: Z
- motherboard: ASUSTeK P8H77-I
- processor: Intel Core i7 3770K 3.5 GHz x 8
- ram: 16 GB
- Video Card: AMD Radeon R7 200 Series
- sound_card: Radeon HD 7700 7800 Sapphire
- Hard_Drive_Capacity: 2x250GbSSD
- Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
- Corel programs: AfterShotPro 1, 2, (3)
Re: ASP3.2 Hangs in Batch Processing
Yes that sometimes (too often) happens also here.
Try to leave the program and start again - this helps sometimes. I also noticed that the z* plugins causes problems. Sometimes switch off zFrame and (or) zText helps (switching on zText later and the image works again). There is also a problem with zPerspector and sharpen (ASP sharpen) and strange grids (patterns) - in this case it helps to change crop a little bit.
These problems are (along with the "no picture available" bug) really bad!
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
austria
