Alpha Channel to Layer / Groups
csh2000
processor: Intel Core i7-6500U CPU 2.50GHz
ram: 12GB
Hard_Drive_Capacity: 1TB
Corel programs: PSP X9, Aftershot Pro 3, VideoStudio X9
Post by csh2000 »
I've been using alpha channels quite a bit for my photography. As I often have many alpha channels, I found the preview under alpha channel selection too small to see the details. Attached are two scripts that I use to help. The scripts below will create a new layer with the visual representation of the alpha channel. This way I can see full screen of the image. I also found it helpful to use these layers to tweak the mask and create a new mask (new mask from image).
By default, the layers are hidden so you can toggle the display on/off.
"Alpha Channel to layer" allows me to select an single alpha channel and create a layer.
"Alpha Channels to group" will create a group with all alpha channels in the group. Warning - depending on the number of alpha channels, size of the image and your system, this could take a minute or so to create. You will get a pop up message when it completes.
Alpha Channels to Layers.zip
(3.5 KiB) Downloaded 240 times
