WinDVD 12 does not start on Windows 10 x64
Moderator: lata
WinDVD 12 does not start on Windows 10 x64. Only for a fraction of second the cursor changes to indicate the program starts. No error message neither on screen nor in Event Viewer.
Doctor9fan
- Video Card: nvidia GeForce 950m
- Hard_Drive_Capacity: 2Tb
- Corel programs: WinDVD 12 Pro. PSP pro 18.
Re: WinDVD 12 does not start on Windows 10 x64
Have you had any previous version of WinDVD installed & if so did you remove it prior to installing the new version?
Do you have any AV software installed & did you disable it prior to installation?
Have you tried opening the program with administrator privelidges - right click on the icon & choose open as admin?
The answer to all of your questions is yes. Moreover, I've tried to reinstall WinDVD several times. After clean install it asks me a single time to choose types of files that should be tied with WinDVD. But the dialog does not respond to any input, and after it's closed WinDVD stops immediately.
Hello all,
I have exactly the same issue. Are there any news on this?
Best Regards gf73
Best Regards gf73
lainofthewired
- motherboard: MSI Z710A Gaming
- processor: Intel i7 6770k
- ram: 16 GB
- Video Card: GeForce 1080 ti
- sound_card: Asus Xonar Phoebus
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Samsung UN46EH6000F
Months later after the last post:
Today I bought WinDVD 12 and I'm having the exact issue. Patching or reinstalling does nothing. Registry cleaner didn't fix it, in case.
I submitted a ticket, but would still like to post here in case someone knows a solution.
lainofthewired
- ram: 16 GB
I hate to double post, but I figured out my issue.
The audio software for my sound card was preventing WinDVD from starting.
I have an Asus ROG Xonar Phoebus. When I close the provided software running in the tray, WinDVD starts up fine, no issue. I can even restart the audio software again after WinDVD is up.
So check to see if your audio software, or something running in the tray, is causing this.
