Wind Noise Filter
Retro69
motherboard: Dell Inc 0M91XC A00
processor: 2.70 gigahertz Intel Core i7-6820HQ
Video Card: Intel HD Graphics 530 [Display adapter] NVIDIA
sound_card: Intel Display Audio Realtek High Definition Audio
Hard_Drive_Capacity: 511GB
Monitor/Display Make & Model: Dell DELL2407WFPHC [Monitor] 24.2 vis, s/n XX-0GM
Corel programs: VideoStudio X9.5
Wind Noise Filter
Post by Retro69 »
Does VideoStudio X9 have any kind of filter to help reduce wind noise in an audio track?
Re: Wind Noise Filter
Post by BrianCee »
If you double click on the audio block in the audio track the options panel will open - in there you will see an icon labelled "Audio Filter"
click on that and you will be presented with a number of filters to apply to the audio - not a "Wind Noise" as such but there is a 'Remove Noise' which you can add then use the options to adjust the threshold - more than one filter can be applied to get the sound changes you require
Retro69
Post by Retro69 »
Ah cool! I'll give that a try!
Thanks.
Not being sarcastic, but the only way to filter wind noise is by using a Windsock, or as they're called a "dead cat" over your mic. I've gone so far as to use some foam cut to be just larger than the mic on a camcorder, and taped it in place. Works in a pinch.
