I am selecting and cutting a head shot out of a frame and want to paste it in another image but probably need to make it smaller to match the other people.
Is this just a simple re-size?
Resizing a selected object in PSP X8
Re: Resizing a selected object in PSP X8
This looks like a pretty good method - https://support.corel.com/hc/en-us/arti ... ntShop-Pro
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
I didn't take the time to follow the reference you provided in detail. Your question was about adjusting size. Once you have selected the head shot, from the menu select edit/copy. Go to the image where it is to be pasted and select edit/paste as new layer. Select the layer and then the pick tool. That tool allows you to adjust the size.
Mark
brucet
Just a caution note. Make sure both images are the same dpi. Otherwise you can get 'strange' results!
regards
regards
Thank you!
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Actually, make sure both images are the same PPI. You can't set or change DPI in a graphic editor because that is a function only of a printer and its software. You'll notice, if you look at the Image information of an image in PSP, it only shows PPI, not DPI, as does the Resize dialogue.
JoeB
Using PSP 2019 64bit
JoeB
brucet
Oops. Ok PPI.
Old habits.
Old habits.
