Hi there, Odd question, whenever I use shadows in overlays in Videostudio, around the black shadow, there's a milky/grey halo around it.
I've tried changing the settings, but no matter what I do the shadow is always there, even stranger it's not there in the video preview :S
I'm currently on the X9 Ultimate edition ATM, but I've literally had this issue for years in previous editions, thought it was my PC originally, but I've switched to a much more powerful machine recently and it's still there.
Can anyone tell me where I'm going wrong?
Thanks!
Shadow Question
Guru Larry
- motherboard: ASUS board of some type
- ram: 32gb
- Video Card: GTX 1080
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung 3DTV
- Corel programs: Videostudio
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Re: Shadow Question
Hi, it's a known bug in the custom motion.
you can decrease it to minimum by setting the border opacity to 0 on all keyframes.
* No... it wont help either.
**the only solution is to apply a mask and use the drop-shadow NB FX
Panasonic X900m, VXF1
Guru Larry
- ram: 32gb
Re: Shadow Question
Ah, excellent. Thank you!
Wow, it's a known bug? how on earth was it not rectified after so many iterations of VideoStudio? I've had it since since at least X5 :S
But thanks for the tip, I've used the drop shadow briefly in the past on images, but I've had to go into photoshop and give the image a large border otherwise the shadow cuts off. But how would I go about applying a mask?
asik1
- ram: 8gb
Re: Shadow Question
Are you kidding? what guru are you ?
Using VS since X5 and never used this tab?
