Images made in PSPx9 - open in PSPx5
Safiren
Post by Safiren »
When a work is made in PSPx9 i can not open it in PSPx5.
I get this message.
Unable to open file. Please verify that the file is valid
How do i do to open in PSPx5 ?
I have:
PSPX9 ultimate
PSPX5 ultimate
PSP 2018
Windows 10
Cassel
ram: 16Gb
Corel programs: PSP 8 (JASC) to PSP 2023
Re: Images made in PSPx9 - open in PSPx5
Post by Cassel »
You need to set up the X9 to save in a compatible mode for X5, when you save it (or once)
So when you go to save your .pspimage file in X9, you will see an Options... button on the bottom right. Click on it.
Then, in Version, Save as... select the PSP X5 compatible file from the drop down list.
Then, your file will be able to be read in X5.
Once you have set this up, you don't have to redo it every time.
WARNING: if you have set up the compatibility to anything before X8, and you are using the Wrapped text feature (in X8 or X9), when you save it, it will DELETE your text completely without warning, even if you want to reopen it in X9.
Cassel
https://scrapbookcampus.com
Safiren
Post by Safiren »
I have not seen the option button before:oops:
Now i see it.
About the wrapped text was a good advice. I din' t know about that either.
Thank you so much.
I have:
PSPX9 ultimate
PSPX5 ultimate
PSP 2018
Windows 10
