External Editor - how to put result back into catalogue
nickholus
operating_system: Linux
System_Drive: N/A
Post by nickholus »
I'm using 3.1 on Linux
I've started to use the External Editor feature to launch another tool, which edits the TIFF and saves back over it. I'd assumed then ASP would import the result and stack it with the original, so when browsing the catalogue I can see the edited version of my images.
It doesn't do that. What's the expected method we get the result back into the catalogue for when browsing our image collection?
Thanks,
Nick
Dutchmm
System_Drive: N/A
motherboard: Asus 97
processor: Intel i7 4785T
Video Card: Onboard Intel
sound_card: Intel AC97
Hard_Drive_Capacity: 2.5TB
Monitor/Display Make & Model: Philips 28"
Corel programs: ASP 3 Pro (and 2 and 1 before)
Re: External Editor - how to put result back into catalogue
Post by Dutchmm »
I don't think the authors' intention was that you should be able to process the image in ASP after you had used an external editor on it. To quote from AFX's Survival Guide:
12.4. Image Editors
When you use an image editor to post-process images from AfterShot,
we strongly recommend that you use 16-bit TIFF files in a wide working
space so that there is no information loss when going from AfterShot
to the external program.
There is a Preferences screen to set up an external editor; you can
specify which program is run on a file when the <CTRL+E> key is pressed.
Using that shortcut will generate a TIFF (or JPEG) file in the directory
of the source file and then call the editor you specified on the Preferences
to edit that file.
No mention of any ability to post-post-process the image. This annoyed me, too, until I read the Survival Guide.
hannes_hab
System_Drive: Z
motherboard: ASUSTeK P8H77-I
processor: Intel Core i7 3770K 3.5 GHz x 8
ram: 16 GB
Video Card: AMD Radeon R7 200 Series
sound_card: Radeon HD 7700 7800 Sapphire
Hard_Drive_Capacity: 2x250GbSSD
Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
Corel programs: AfterShotPro 1, 2, (3)
Post by hannes_hab »
when I use the external editor (in my case 16 bit tif and gimp 2.9.3 on llinux) and edit the image there it is re-imported into the catalog.
You must save (not save as) - here in gimp "overwrite xxxxx_edit.tif" (ASP 3.1. on ubuntu 12.04 with gimp 2.9.3)
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
