Inconsistent Pen Tool
pdxrjt
processor: Intel Core i7 - 4.2 GHz
ram: 32 GB
Video Card: NVIDIA GeForce GTX 1080
Hard_Drive_Capacity: 10TB Int.
Monitor/Display Make & Model: Acer 32 inch x2
Corel programs: Paint Shop Pro 2018
Post by pdxrjt »
I don't use the pen tool much, but when I do it is usually to draw non-connected straight lines. As far as I know, I understand most of the tool and how to use it. The last month or so I have been having an unusual problem. I have the photo where I want to draw a straight line. I will start to draw...... sometimes the first one shows up, sometimes it does not. If the first one shows up, the second one does not...... huh? I have not change any settings and am on the correct vector layer which is the top layer and showing. If I continue to draw, close the image, or sometimes close the program I can get it to finally finish the lines. I am using PSP X8 Ultimate with the latest updates on Win 10. No problems until the past month or so.
Adverts for Corel products when you close PSP don't bother me.
xfsgpr
Hard_Drive_Capacity: 1 TB
Corel programs: PSPX6, x7, x8, x9, 2018,2019, 2020
Re: Inconsistent Pen Tool
Post by xfsgpr »
Have you tried to reset the defaults? If not go to:
File >> Preferences >> Reset preferences
See this image:
Good luck.
pdxrjt
ram: 32 GB
Post by pdxrjt »
Hmmmmm, I have not tried reset. Think I will now. Thanks much. (Can't believe I didn't remember to try that, seems to work fine now.) Tried it off on and for several hours..... working as before. Duh...reset, reset, reset! Thanks again!
data_design
motherboard: Dell Inc. 0XFWHV A00
processor: 2.70 gigahertz Intel Celeron G1620
ram: 8gb
Video Card: Nvidia GeForce 210 1gb w-CUDA
Hard_Drive_Capacity: 500gb
Monitor/Display Make & Model: Hanspree HT231
Post by data_design »
I have the same problem with the pen tool but reset did not work. Pen tool used to work, but not anymore is there another way to fix?
I did not reset everything and it did not work. Please help.
After a while I found a tiny button that says "Show Nodes" and it began working.
My question is: Why did the "Show Nodes" button get set to not show?
Guess it does not matter now.
