How can I apply a deformed image to another object?
hexaae
motherboard: Gaming laptop ASUS G751JY
processor: i7-4860HQ
ram: 24GB
Video Card: GTX 980m 4GB g-sync
Hard_Drive_Capacity: SSD 2TB
Monitor/Display Make & Model: LG Display LP173WF4-SPD1, 1080p 75Hz
Corel programs: PaintShop Pro X9 Ultimate
Post by hexaae »
I wanted to apply as a texture an image to a blank book page.
I know I can deform an image area keeping perspective proportion, but in my case I need to adapt it to a curved/deformed surface and not to a simple rectangle...
Is it possible to do something like this with PaintShop Pro X9? --- https://www.youtube.com/watch?v=XLdLwxt0nB8
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: How can I apply a deformed image to another object?
Post by Jean-Luc »
You may try the Mesh Warp tool and apply a deformation map or do it manually.
But PSP is not able to Mesh Warp "outside" the image. The image stays rectangular.
Other softwares can do that (Photoshop, Affinity Photo and if I remember CorelDraw too).
If you want to deform the rectangle itself (borders), apply a large "empty" border around the image. So you may deform the borders too (and remove the unwanted area after deform).
Charlie77
motherboard: ASUSTeK CM6870 - LGA1155
processor: Intel Core i7 3770 - 3.40GHz
Video Card: NVIDIA GeForce GT 620 DDR3 2048MB 64bit
sound_card: On motherboard Realtek High Definition Audio
Hard_Drive_Capacity: 5TB
Monitor/Display Make & Model: Dell ST2310 1920x1080
Corel programs: ASP 3, PSP X9(My Preference), PSP 2018
Post by Charlie77 »
PSP does not have a dedicated feature to warp an image to a surface, but with the use of the Mash Warp Tool it is very doable.
1. Bring the base image and the image to be used as a cover into PSP
2. Copy the cover image and past as new layer in the base image
3. Reduce the opacity of the new layer so you can see the base image
4. use the Pick Tool to size and place the cover image on the base image
5. Use the Canvas Size tool to create more room to work
6. Use the Warp Tool to adjust the cover image to fit properly on the base image
7. Re-adjust Opacity, Merge layers and Crop as needed to create a finished image
I hope this helps
Charlie
photodrawken
ram: 16Gb
Hard_Drive_Capacity: 324Gb
Post by photodrawken »
Jean-Luc wrote:But PSP is not able to Mesh Warp "outside" the image. The image stays rectangular.
And PhotoLine.
Ken
hexaae
ram: 24GB
Post by hexaae »
Charlie77 wrote:PSP does not have a dedicated feature to warp an image to a surface, but with the use of the Mash Warp Tool it is very doable.
I hope this helps
Charlie
Very useful thank you. Undervalued the power of Mesh Warp to adapt the image to the curved page surface manually...
- A happy newbie user coming from Photoshop :)
P.S.
Please, consider "something similar to PS Smart Objects manipulation" a feature request for next PSP to easily load and reapply any image to the mesh.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
You can save and load a warp that you made. It's not very advanced but you can do it.
On the tool options palette you'll see an option for "deformation Map" with a load icon (folder) and a save icon (diskette). Once you've made your warp, and before you apply it, hit the save icon to save the warp. It'll ask for a name for this new warp so make sure it matches what you need.
Then to re-load that warp on a new image just hit the load icon and select your warp from the list. This works for both the warp brush and the warp mesh.
hexaae
ram: 24GB
Post by hexaae »
Great! A bit "complicated" but actually a powerful feature, thank you all for the hints...
The more I use PSP the more I discover it was a very good purchase that can actually replace other well known paint/photo-editing programs.
