How to remove or cut details OUTSIDE a selection
Stokkers
motherboard: ASUSTeK COMPUTER INC. A58M-K Rev X.0x
processor: 3.90 gigahertz AMD A8-6600K APU with Radeon HD Gra
ram: 8192 MB
Video Card: ATI RADEON XPRESS 200
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Hanns. HT231
Corel programs: PSP X8
Post by Stokkers »
Hi all
Have a square image that I would like to convert as a circle. Have got as far as seleting the area i want, but how do I now remove the bits I don't want, or change them to transparent?
Thanks.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: How to remove or cut details OUTSIDE a selection
Post by LeviFiction »
Invert the selection (Selections -> Invert) so that it's not selecting what you want to keep, but selecting everything you don't want to keep. Then use your delete key or the clear command (Edit -> Clear) You can also use the eraser if you want.
Stokkers
ram: 8192 MB
Post by Stokkers »
LeviFiction wrote:Invert the selection (Selections -> Invert) so that it's not selecting what you want to keep, but selecting everything you don't want to keep. Then use your delete key or the clear command (Edit -> Clear) You can also use the eraser if you want.
Thanks Levi,
I tried the eraser, but that didn't work, so I'll try your other suggestion.
Stokkers
ram: 8192 MB
Post by Stokkers »
I managed to remove but it is a white, will this be transparent when I place onto a coloured backgraound, or is that something else I need to learn?
ram: 6 GB
There are two kinds of raster layers. Background and Raster. A background layer does not support transparency. So when you delete anything on a background layer it'll fill with the background color in your materials palette. If you need transparency you must first promote the background layer to a regular raster layer.
To do this you can either right-click on the layer and select "Promote background layer" or go to the layers menu and select Layers -> Promote Background Layer. Once you've done this, hit the delete button again.
Stokkers
ram: 8192 MB
Post by Stokkers »
Many thanks, Levi. Looks a treat now and hopefully will look great on my new website! Well, when I get around to building it!
Thanks M8!
