VSX9 Scroll Text Horizontally
I want to scroll text horizontally from right to left across the bottom of the screen. I'm sure that it is possible, but I haven't been able to figure out how to do it.
Re: VSX9 Scroll Text Horizontally
see if this helps you -- https://www.youtube.com/watch?v=MA50RQvsvuE
You can of course also use 'customise motion' like this - - https://www.youtube.com/watch?v=w7OLC4zMhY4
This was just what I needed. Thanks
alanball
- motherboard: Gigabyte Technology B450M H
- processor: AMD Ryzen 5 3600 6-Core
- ram: 16 GB
- Video Card: NVIDIA GeForce GTX 1660 SUPER
- Hard_Drive_Capacity: 2TB+480SSD
- Monitor/Display Make & Model: ASUS VN247
- Corel programs: VS10, VS2018 Ultimate, VS2021 Ultimate
Hi all
I have just had a need for scrolling text moving with the words of a song and I used BrianCee's second option. It's over a video with a changing background, so I tried to insert a 25% text backdrop, but the backdrop would not follow the text across the screen. Any ideas how to overcome this?
Thanks.
Thanks.
Alan Ball
are you using the actual "text backdrop" function in the title options panel ? - using that I have no problem at all with scrolling text and backdrop together
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Brian, no scroll for me either.
not by choosing Text nor Line.
Panasonic X900m, VXF1
must be something different in my programme then - see it in action here - - https://youtu.be/MailoM9CJnA
when you move the text around the preview screen manually using the mouse does the backdrop move with it
I think Brian has used Customise Motion after creating the text rather than Text Animation
lata wrote:Hi I think Brian has used Customise Motion after creating the text rather than Text Animation
Yes that is what was said in the previous posts above
alanball
- ram: 16 GB
Hi each,
it was the text animation I was referring to.
Alan Ball
alanball
- ram: 16 GB
Hi Brian
yes, the background moves with the text when moved with the mouse, but when played the text moves across the screen but the background just stands still.
Alan Ball
alanball wrote:Hi all
Thanks.
The "second option" uses "Customise Motion"
alanball wrote: Hi each,
So not the second option then
I'm going for a long lie down in the dark
asik1
- ram: 8gb
I do have some problems in english , but where Customize Motion is hiding in that answer?BrianCee wrote:are you using the actual "text backdrop" function in the title options panel ? - using that I have no problem at all with scrolling text and backdrop together
** Thanks alan for bringing up another bug in the titles tool (probably since ulead)
alanball
- ram: 16 GB
Sorry for confusion Brian, that's one of the problems living down here in New Zealand, we are upside down compared with you in the UK!!
I have tried the track motion option, not quite the effect I was after, as the text has to start at the left hand side of the screen, (not comming in from the right) so that the colour backing is across the screen continually from left to right and remains there until the line of text (about 2 screen width's) has finished crossing the screen, and departs to the left of screen. But I will use that for now.
That's one of the things with Video Studio there is usually an alternative way to do things.
Many thanks for your input.
Alan Ball
Not sure what is going on here but is the attached project what you are trying to do?
From the text options panel when setting transparency, make sure the top options are set to Fit to Text not Solid Background.
