X9 -Can't change file locations
Rick_R
motherboard: ASUSTeK Computer INC F2A85-V Pro
processor: AMD A6-6400K APU
Video Card: PowerColor AMD Radeon R7 240 2GB DDR3
sound_card: On-board Realtek and AMD High Definition Audio
Hard_Drive_Capacity: 16TB+375GB
Monitor/Display Make & Model: SEIKI SE39UY04 39in 4K UHD TV
Corel programs: PaintShop Pro 12-2022 Ultimate
Post by Rick_R »
I finally have installed X9 and I'm trying to do something I always do but it's not working -- changing the file locations for Brushes, etc.
I have a location that contains the various Corel_0x files from different versions. When I do a new install, I add File Locations to point to those, then I delete the Corel default paths, since all of those items are already in the new location.
The problem I'm running into is that X9 is refusing to "take" the deletions. It lets me do the deletions, showing that there defaults are no longer there. But when I shut down X9 and restart it, the paths I deleted are back, and X9 tells me that there are loads of duplicates, because the files have the same name in both locations.
The problem exists in both the 32- and 64-bit versions. I'm using Service Pack 3.
Kathy_9
Hard_Drive_Capacity: 2TB
Re: X9 -Can't change file locations
Post by Kathy_9 »
As far as I know you can add locations but you can't delete the default locations. I know this because I've tried and not just with X9 but previous versions as well. I too get the notifications about duplicates but I only see this notification once. You could always go into the default locations and delete the contents. I've never tried that so I don't know if they will rebuild or not.
