Recording/Modifying/Writing Scripts LOOPS
XUUQ
Corel programs: x8 x9 particle shop
Post by XUUQ »
what codes do i need to make a loop that repeats a functioning such as drawing a line more than 1 time? this script was recorded only drawing a straight line and i would like to loop the same line being drawn multiple times.
and if you know how to do that, then how do you do calculations within this script? i know this is a modified Python code, but it looks similar to commodore 64 basic language, which i was very good at doing.
from PSPApp import *
def ScriptProperties():
return {
'Author': u'',
'Copyright': u'',
'Description': u'',
'Host': u'PaintShop Pro',
'Host Version': u'19.00'
def Do(Environment):
# EnableOptimizedScriptUndo
App.Do( Environment, 'EnableOptimizedScriptUndo', {
'GeneralSettings': {
'ExecutionMode': App.Constants.ExecutionMode.Default,
'AutoActionMode': App.Constants.AutoActionMode.Match,
'Version': ((19,0,0),1),
'PreviewMode': 1,
'ScreenControl': 1
# PaintBrush
App.Do( Environment, 'PaintBrush', {
'BrushTip': {
'Shape': App.Constants.BrushShape.Round,
'CustomBrush': u'feather',
'Size': 11,
'Hardness': 100,
'Step': 32,
'Density': 100,
'Thickness': 100,
'Rotation': 0,
'BrushVariance': {
'SizeVariance': App.Constants.VarianceMethod.Pressure,
'SizeJitter': 0,
'OpacityVariance': App.Constants.VarianceMethod.None,
'OpacityJitter': 0,
'DensityVariance': App.Constants.VarianceMethod.None,
'DensityJitter': 0,
'ThicknessVariance': App.Constants.VarianceMethod.None,
'ThicknessJitter': 0,
'RotationVariance': App.Constants.VarianceMethod.None,
'RotationJitter': 0,
'ColorBlendVariance': App.Constants.VarianceMethod.None,
'ColorBlendJitter': 0,
'HueVariance': App.Constants.VarianceMethod.None,
'HueJitter': 0,
'SaturationVariance': App.Constants.VarianceMethod.None,
'SaturationJitter': 0,
'LightnessVariance': App.Constants.VarianceMethod.None,
'LightnessJitter': 0,
'PositionJitter': 0,
'UseScaledPositionJitter': False,
'ImpressionsPerStep': 1,
'FadeRate': 100
'BrushTrayShow': False
'Brush': {
'Opacity': 100,
'ContinuousPaint': False,
'WetLookPaint': False,
'BlendMode': App.Constants.BlendMode.Normal,
'CAMG': {
'SupportCAMG': False,
'EngineType': App.Constants.CAMGEngineType.MagicWand,
'FeatherDegree': 0,
'AntiAliasing': 0,
'MagicWand': {
'MatchMode': App.Constants.MatchMode.None,
'Tolerance': 0,
'Contiguous': False
'Segmentation': {
'ObjectExtractor_PCA': {
'PrimaryMaterial': App.Constants.MaterialRef.Foreground,
'ForegroundMaterial': {
'Color': (0,0,0),
'Pattern': None,
'Gradient': None,
'Texture': None,
'Art': None
'BackgroundMaterial': {
'Color': (255,255,255),
'Pattern': None,
'Gradient': None,
'Texture': None,
'Art': None
'Stroke': [
(App.Constants.PathEntryInterpretation.Absolute,(292.5,571.5),0),
(App.Constants.PathEntryInterpretation.Absolute,(292.5,571.5),31)
'RandomSeed': 30840411,
'PreviewMode': 1,
'ScreenControl': 1
# PaintBrush
'BrushTip': {
'Size': 11,
'Hardness': 100,
'Step': 32,
'Density': 100,
'Thickness': 100,
'Rotation': 0,
'BrushVariance': {
'SizeJitter': 0,
'OpacityJitter': 0,
'DensityJitter': 0,
'HueJitter': 0,
'FadeRate': 100
'Brush': {
'Opacity': 100,
'CAMG': {
'FeatherDegree': 0,
'AntiAliasing': 0,
'MagicWand': {
'Tolerance': 0,
'Contiguous': False
'Segmentation': {
'Color': (0,0,0),
'Pattern': None,
'Gradient': None,
'Texture': None,
'Art': None
'Pattern': None,
'Gradient': None,
'Texture': None,
'Art': None
'Stroke': [
(App.Constants.PathEntryInterpretation.Absolute,(1465.5,556.5),0)
'RandomSeed': 30842144,
'PreviewMode': 1,
'ScreenControl': 1
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Recording/Modifying/Writing Scripts LOOPS
Post by LeviFiction »
It's not even modified, Python. It's pure python. The "from PSPApp import *" is what imports the App.Do() function and other objects/constants for use in a script. But technically, so long as you put your code inside the "Do" function it'll run anything.
For loops in python are pretty easy if you want to loop only a specific number of times. If you want to loop based on input that'll be the while loop.
Code: Select all
for x in range(10):  #runs the loop 10 times, setting x = 0...10
    #Add PaintBrush command here
[code]
Now, you want to make a whole bunch of lines, but in what sort of pattern?  How you do it depends on what you want it to do.  If you only want to build up the exact same line in the exact same spot several times, you don't need any calculations.
