"Error 1303.The installer has insufficient privileges to access this directory: c:\ProgramData\Corel\Corel PaintShop Pro X9. The installation cannot continue. Log on as an administrator or contact your system administrator."
At the end of the log file was the message:
"Result: 1603 -- Fatal error during installation."
Solution---
1. Manually create the "\ProgramData\Corel\Corel PaintShop Pro X9" directory.
2. Change the permissions of the directory to "Take Ownership" of the directory and allow full access.
3. Run the X9 installation as administrator (Right click, select "Run as administrator").
4. In my installation, the Target directory created in the Windows Startup Directory was not correct.
- installed as - "C:\Program Files (x86)\Corel\Corel PaintShop Pro X9 (64-bit)\Corel PaintShop Pro.exe"
- should be - "C:\Program Files\Corel\Corel PaintShop Pro X9 (64-bit)\Corel PaintShop Pro.exe"
