What are the best parameters for final quality, regardless size, to render a final video?
Thanks.
Best resolution to make a vídeo
alfons
- processor: i7 9700
- ram: 32GB
- Video Card: Gforce GTX1650
- sound_card: Sound Blaster Audigy FX
- Hard_Drive_Capacity: 1TBSSD+4GB
- Monitor/Display Make & Model: HP 24Uh
- Corel programs: VS X4-X5-X8-X10-2018-2020-2022
Re: Best resolution to make a vídeo
Alfons -- how long is a piece of string?
Your question is a bit like that one. You don't tell us what the video is for -- to be made into a disc (DVD or Blu-Ray?), for showing on the web (high def or standard def?), for playing on a HDTV e.g. from a file stored on a card or USB drive. Each of these -- and probably more -- will have its own versions of "best" in terms of format, bitrate, frame rate, Upper (or Lower) Frame First or Frame Based/Progressive, and even audio format and its own bitrate...
So give us a bit more of a hint and maybe you will get some sensible answers.
alfons
- ram: 32GB
Sorry Ken you are right.
I have a Screenplay director which can play most of formats plug into a Hdtv. My question was how to obtain the best quality video before having to try different finishes on the tv.
John-T-Smith
- motherboard: ASUS Sabertooth
- processor: Intel i7
- ram: 32 Gig
- Video Card: nVidia GTX760 2Gig
- sound_card: Motherboard
- Hard_Drive_Capacity: 1152 4SSD
- Monitor/Display Make & Model: Samsung P2770
- Corel programs: VSX9 (19.5.0.35)
Quality begins with the filming process... set your camera to record at the "best" quality it can
Edit your video using that video setting in the project, to maintain "best" quality
When you are ready to use the SHARE option to create a finished output is when you will select your target output setting
Canon SX510 HS - MOV H.264 24bit color 1280x720 29.97 fps LPCM 48khz audio
All SSD - 256Gig Boot + 256Gig Temp + 512Gig Input + 128Gig for all Output
Grass Valley ADVC 110 via Firewire IEEE1394 cable to convert analog to digital
