Merge video and audio tracks
akmiecik
operating_system: Vista Business
motherboard: LENOVO 74542JU
processor: 2.40 gigahertz Intel Core2 Duo P8600
ram: 2GB
Video Card: ThinkPad Display
sound_card: Conexant 20561 SmartAudio HD
Hard_Drive_Capacity: 160GB
Monitor/Display Make & Model: n/a
Post by akmiecik »
Is there a way to merger video and audio tracks without rendering?
I'm merging a lecture audio with slides. I have all the in/out for the slides but need to be able to keep those while editing the video.
Currently plan is to render then edit the resulting video.
Thanks.
Re: Merge video and audio tracks
Post by BrianCee »
bit confusing there - first you don't want to render - then you seem to want to do a render before editing for some reason
when you create a "project" by saving and creating a .vsp file you have effectively 'merged' video/slides/audio into one "lump" and as long as you keep editing and playing on the one PC they are to all intents and purposes all joined together
for what you want to do why can you not use the standard techniques of editing both pictures and audio within a project and saving and opening it at will
then when all editing is complete you can render to create the final video which you can play any where
akmiecik
ram: 2GB
Post by akmiecik »
don't know how you figure you make one lump when you create a vsp, upon opening, it is still multiple tracks and editing one track changes timings (think chapter points or cues) means editing the other track(s) and ensuring everything is still in sync.
"for what you want to do why can you not use the standard techniques of editing both pictures and audio within a project and saving and opening it at will" -> therein lies the problem. I need to edit visuals and audio simultaneously (not concurrently).
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
What VS you use?
once you set your slides with the audio, save that VSP
and drag it as a single track to re-edit with the video if this your desire.
Panasonic X900m, VXF1
