Lost info when installing on new computer
mikeandm
motherboard: Micro-Star International Co MS-1795
processor: Intel Core i7-6700HQ CPU
ram: 3936
Video Card: NVIDIA GeForce GTX 960M
sound_card: Realtek High definition
Hard_Drive_Capacity: 1233GB
Monitor/Display Make & Model: Generic PnP moniter
Corel programs: Videostudio 22
Post by mikeandm »
Not sure if you can help. I have just changed my laptop to a new one and have reinstalled videostudio 8.5. In addition I also copied and moved over the corel working folder 18 and installed that into the Corel folders in the same place. I then started the program and opened the project that I was working on. The project has opened with all the files that I had but with the exception of the title and transitions, all are showing in the black and white stripe which always showed an un-linked file. Previously I have had a window open up to advise that some files were not linked and allowing me to find the file and re-link it. This time I cannot get either the window showing the fault or the clip itself to give me a way to re-link it
Any ideas what I can do?
Re: Lost info when installing on new computer
Post by BrianCee »
First try clicking on a black and white clip - that may bring up the relink offer - if that doesn't work try RIGHT clicking on the clip - and choose 'replace Video/audio' (as appropriate) then browse to the clip and select it
mikeandm
ram: 3936
Post by mikeandm »
Hi Brian,
thanks for your speedy response. Unfortunately clicking the link or right clicking the link only brings up the same response. If I then select replace clip I only get the opportunity to replace the whole clip into each segment. In other words I have to edit the whole clip again. I was hoping to find out, if possible, where the editing instructions are stored. I still have the program and edited project in situ on the old computer and so if I knew which folder it is stored in I would be able to transfer it to the new one.
Post by BrianCee »
The editing instructions are stored in the .vsp file - but if you find a way to read them to the point of making use of the information then as far as I know you will be the first person outside of Corel to do so
You need to move all files used in your project to the new computer.
Your best option is to create a Smart Package using the old program / computer.
Then move the entire SP folder to your new pc.
The Smart Package option saves copies of all your clips used in the project along with a project file VSP
When you open on the new pc you may have to do one re-link, other than that your project should now open ok.
Although if you have used FX filters then there may be some issues, tweaks to do.
Post by BrianCee »
Suddenly occurred to me - as this is a new installation have you checked in "Setting >> Preferences" that 'Relink checking' is ticked - in the top right corner of the general tab
mikeandm
ram: 3936
Post by mikeandm »
Hi and once again thanks for the responses.
It appears that I was a bit of an idiot, I had never spotted the relink check box and that seems to be the problem.Strangely I had managed to fix it by installing a copy of VS7 and starting in that, which obviously had the box ticked. Anyway all working now thanks.
Hi Mike
No! not an idiot, rather a change in the program, older versions always had re-link selected.
For some reason CVSX9.5 has that option deselected. Corel are aware of that change.
