I know this sounds stupid, but how do I draw a simple empty rectangle in X8? When I pick the Rectangle tool it gives me a bunch of diamonds around the area I selected. I just want to put a red empty rectangle around a portion of an image to point it out--the way you would put a red outline in Acrobat or Adobe Reader. When I tried doing that with Photoshop Elements 12 at least it gave me a filled red square.
I checked LeviFiction's YouTube videos on how to use the rectangle tool but mine isn't working like that.
How to draw a hollowed rectangle in X8?
Rick_R
- motherboard: ASUSTeK Computer INC F2A85-V Pro
- processor: AMD A6-6400K APU
- Video Card: PowerColor AMD Radeon R7 240 2GB DDR3
- sound_card: On-board Realtek and AMD High Definition Audio
- Hard_Drive_Capacity: 16TB+375GB
- Monitor/Display Make & Model: SEIKI SE39UY04 39in 4K UHD TV
- Corel programs: PaintShop Pro 12-2022 Ultimate
- hartpaul
- ram: 8 Gb
Re: How to draw a hollowed rectangle in X8?
I just tried in X8
Opened a new document with white background.
On Material palette selected a red as Foreground color and Transparent as Background / Fill color.
Selected the Rectangle tool (under Preset Shapes) just below the Text tool.
Changed the width (just past the Line style box) to say 10
Drew the rectangle and the box with no fill appeared.
Rick_R
I tried those on the image I'm trying to put the box on and I'm still getting the problem.
If I uncheck Show Nodes I don't get the light blue square. But the red diamonds are still there.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Looks like you have a line-style problem. Have you tried setting your line style to something else? From the screnshot it looks like the line style is set to a solid line. Try something else and see if that gets rid of the diamonds. If not have you tried resetting your workspace?
- hartpaul
- ram: 8 Gb
Also uncheck show nodes. and click the tick for apply.
Forriner
- motherboard: ASUS Z170M-PLUS
- processor: Intel Core i5-6400
- ram: 16 GB
- Hard_Drive_Capacity: 1250 GB
- Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
- Corel programs: PSP 2023
It looks like you have a customized line style.
Click on the "line style:" of the Tool Options and click the Custom button of the drop down.
Check if the 'Different segment caps' option is checked. Below that you can vary the length in the 'Style' box.
I'm no expert, but unchecking something here might help.
Rick_R
Thanks!
No, I didn't have it set as a line. It turns out the "example" image in the drop-down is a "line" of very tiny dots. I thought that was showing a solid line, so I didn't use the drop-down to check the line style.
Cassel
- ram: 16Gb
- Corel programs: PSP 8 (JASC) to PSP 2023
I don't know why, but i have often gotten that line style change on its own. I NEVER use it on purpose and i often get it when i don't want. Not sure why.
Cassel
https://scrapbookcampus.com
Rick_R
It wasn't an accidental change. I had not used the line style for quite awhile. When I looked at the line style I thought it was a straight line. I didn't realize it was it was dotted until I looked at the drop-down.
