Look this video:
https://youtu.be/jTDOuDDk8YE
In older versions of CVS this bug appears, too !!
But now today I have ultimate made a movie from this "crazy bug".
NewOld Text-Animation bug in CVS X9.5 (pause long/short)
- solarkritik
- motherboard: h8-1335ez
- processor: INTELi7-3770 CPU 3.40GHz
- ram: 8 GB
- Video Card: AMD RADEON 7570
- sound_card: AMD HighDefinition Device
- Hard_Drive_Capacity: 1000 GB
- Monitor/Display Make & Model: Two monitors: Toshiba and Benq
- Corel programs: VSX9.5 (since July 2016)
I'm using "VIDEOSTUDIO" since 2005: using since Ulead 5+6+7 -->> COREL VIDEO STUDIO 10+11+12+14+15+17+19+19.5+20 WIN 10
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Re: NewOld Text-Animation bug in CVS X9.5 (pause long/short)
My german is very bad. if you explained in english instead of bad music, may be we can help.
Here I have no problem in making short character fades.
** Your problem is that you keep pressing that animation. it's default start point is long, if you want short, select it and OK, that's it. It set to short, you can see that the bar under the screen has changed.
Panasonic X900m, VXF1
It is not a problem
The two “TT’s” is a manual approach to setting animations pause durations.
This option reverts to using the last applied pause duration.
So if you create a text and use “TT” to set “Short” then the next text using TT will also use “Short”
When you press the pre-set animations you are setting those affects, the one you chose used “Long” pause duration.
Again the two “TT’s” will use the last applied pause duration which is now “Long”
Clears as mud
It is not a problem
Clears as mud
- solarkritik
- ram: 8 GB
No, sorry lata, that is wrong, what you say.
I have tested it once more.
Look the new, second video.
In both options the pause has the equal length
https://youtu.be/GA8WtlJ_Rx4
How can I change the "pre-set-animations" ??
asik1
- ram: 8gb
It seems we don't fully understand your issue,
Have you tried setting the preview bar to your needs?
- solarkritik
- ram: 8 GB
Thanks, asik1, that is the solution.
This "preview bar" I have never seen and never recognized in so many years I am working with CVS.
This "preview bar" has brought the solution I want.
Many thanks, asik1.
Many thanks, asik1.
That bar is quite useful for many things, please see this web page for further info on the Blue Bar / preview bar
http://lata.me.uk/corel/trimbar/trim_bar.htm
Notice that when you manually adjust the blue bar the pause duration now shows as User Defined
