I shoot my video in 1080 on a Panasonic HLC - HS900 with a view to rendering it to Mt2 for burning to Blu-ray and possibly an MP4 version. After rendering a project to Mt2 today I noticed an occasional break up on some clips in the project (not present on the source video or apparent when editing) consisting of a stack of straight horizontal lines on the vertical frame edge and vertical lines on the top or bottom of the frame edge intruding into the frame. I have never had this before and cannot see anything similar in FAQ.
I have tried rendering both with and without 'Smart' render but it makes no difference.
Any thoughts please?
Many thanks,
Andy
Picture break up on frame edge(s) after rendering.
Andy3T
- motherboard: Acer JV51
- processor: 2.00 gigahertz Intel Core i7-2630QM
- Video Card: Intel R HD Graphics Family
- sound_card: Intel R Display Audio
- Hard_Drive_Capacity: 585.37 Gig
- Monitor/Display Make & Model: ACER 5755G
- Corel programs: Videostudio X9.5 Ultimate
- aljimenez
- motherboard: Dell Inc. A08 4.16.2014
- processor: IntelCore i7-4790 3.60GHz 4Cores 8 Logical Proc
- ram: 24GB
- sound_card: AMD High Definition Audio
- Hard_Drive_Capacity: 500SSD+2TB
- Monitor/Display Make & Model: Three monitors, all Dell brand, one 4K
- Corel programs: Visual Studio, Paintshop
Re: Picture break up on frame edge(s) after rendering.
Need to know which version of VS you are using, and perhaps may need details on the properties of the video clips and the properties of the project. I suspect there is some format conversions going on that might explain the breakdowns you are seeing.
User for more than 10 years.
Andy3T
Hi Al
It's X8 and I've matched the properties of the clips and the project as I always do. I've just tried rendering the project to MP4 and get the same result there.
Thanks for interest.
Andy
Andy
canuck
So what are the properties of the source clips and the properties of the rendered clip?
Andy3T
Source video;
H264
24 bits
1220 x 1080, 16:9
50,000 fps
variable bit rate 26,000 kbps
Rendering to Mt2 (as I always do) to burn to BD.
Rendered properties;
1920 x 1080
Data rate 19083 kbps
Total bit rate 19467 kpbs
25 fps
Any thoughts?
H264
24 bits
1220 x 1080, 16:9
50,000 fps
1920 x 1080
25 fps
Any thoughts?
Are you sure the frame format of the original video is 1220 x 1080 and not 1440 x 1080? The 1220 part would be very unusual and could account for at least the lines along the top and bottom (though they are still very unusual too), but not along the sides...
Andy3T
Sorry Ken, it should read 1920. I typed the details late last evening here in the UK and didn't have my specs to hand. I don't seem to have done anything differently from what I would normally, so it's quite a mystery. I have used the anti shake filter rather more than I have in the past but the problem appears even on the clips were a filter wasn't employed.
As an aside, I've been using the 'standard' anti shake effect from the FX library but shouldn't the Pro Dad Mercalli filter also come pre-loaded in the X8 FX library?
Andy
Andy
Andy3T
Thought it might be sensible to provide these links to illustrate the problem
https://drive.google.com/file/d/0B8dMIY ... sp=sharing
Andy
Andy
Andy3T
Andy3T wrote:Thought it might be sensible to provide these links to illustrate the problem
Andy
Seems I've got to the bottom of the problem now. It's to do with the anti shake filter. Delete this effect from each clip and the problem goes away.
Thanks for input/suggestions. I've also found out that pro day Mercalli only comes with 'Ultimate' and not 'Pro'
Andy
