NEED HELP!!! blacked out clips and previews....
streamside88
Post by streamside88 »
recorded this video instead of explaining on here... hopefully somebody can help. I just bought the program and I cant work with it this way...
https://www.youtube.com/watch?v=ICdSo2-Z5o0
Re: NEED HELP!!! blacked out clips and previews....
Post by BrianCee »
You have un-linked the thumbnail in the timeline from the original video
did you insert direct from a camera or SD card and then remove the camera/SD card from your computer
after you had inserted the video to the timeline did you do anything at all to the actual video - move it to another folder - rename it - delete it - anything ?
what you see in Videostudio is not the actual video - it is a thumbnail link to the video which must be somewhere on your computer that Videostudio can access all the time - so when editing in Videostudio you first need to move/copy your videos to a folder which is always accessible to VS - then when you insert/import in VS you will not have this problem
delete the black and white image in the timeline and start again
streamside88
Nope all I did was unload the videos from my camera onto my computer and uploading the videos from the file on my comp to the program...
Post by BrianCee »
OK - delete the black and white block in the timeline - then RIGHT click over the top timeline and choose "Insert Video" - use the dialogue box which opens to browse to the actual video file - select it and then click on 'open' - does the video now appear correctly ?
weaver
processor: intel i7
Video Card: nvidia Ge Force GF 550 Ti
sound_card: C.Media
Hard_Drive_Capacity: 20TB
Monitor/Display Make & Model: FULL HD
Corel programs: VS S6,8,10 on W XP, VS X4,6,7,2018
Post by weaver »
You can also try to click on the B/W timeline picture with the right mouse button a replace the clip ( in this case yiu have to select the same clip from your archive - you will see what will happen.
streamside88
its not a problem of inserting the video into the track or timeline because even the preview is glitched out.... watch the video...
https://www.youtube.com/watch?v=eqRBWFANS20
Post by BrianCee »
Do you have the latest version of Quicktime player installed on your computer - I have it as version 7.7.9
streamside88
yes
streamside88
Ok so i used a file converter to convert a clip from .mov to mpg and it seemed to fix it but now the audio from the clip is absolutely destroyed......And i can play the files on quicktime no problem....
canuck
operating_system: Windows 8.1
Post by canuck »
Could you upload that clip to a website like Dropbox or OneDrive so that we could download it and have a look at it?
BTW, what is make/model of the camera/camcorder?
streamside88
so i got a wierd message when i tried to use fastflick....... I'm using a nikon aw110 waterproof camera
corel vs
corel vs
streamside88
Is this acceptable for a computer to run this program on because it seems to work very fast and smooth no issues other then this one?...
streamside88
Here is one of the files off my camera
https://www.dropbox.com/s/50s7f70b1ryp5 ... 4.MOV?dl=0
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
Every time I click on the Dropbox link, it crashes Firefox, never had that issue before
Opens fine in Edge. Just downloaded it.
It inserts into my X9 library just fine, with image. And has the image when I drop it in the timeline. Plays fine in both clip and Project mode with or without being selected.
EDIT: I should have added a photo -- see below.
