Same as project settings Vs9 bug?
Wayne1158
Post by Wayne1158 »
When creating a video file i use "Same as project settings" however the rendering is very slow in version 9. I always used this in version 8 and it was very fast. Is this a bug? Looks like I will have to go back to version 8, and I thought new program versions were supposed to be improvements, LOL :?
GeorgeW
Post by GeorgeW »
Do the project settings match the attributes of your source videos :?:
If not, then you will be re-encoding to the new settings...
George
Wayne1158
No
Post by Wayne1158 »
No they dont, so the queation is why when you select to save same as project settings version 9 seemsw to change the encoding to something else?
This worked flawlesly in vrsion 8.
Wayne1158
Post by Wayne1158 »
Mistake, yes it does encode in the same format, but VERY slowly. I just reinstalled version 8 and it saved the file in a few minutes, 100 times faster than version 9
THoff
Post by THoff »
Can you post the properties of the file you are testing this with?
Wayne1158
Post by Wayne1158 »
Format: 24 bits, 480 x 576
Compression: PAL SVCD
Com. Ratio: 3%
Frame Rate: 25
Audio: MPEG audio layer
