Project has music but the track is not separate
rkstudio
motherboard: There is no motherboard listed
processor: Intel Core i7-855ou CPU 1.80 GHZ
Video Card: Radeon 540 Graphics
Hard_Drive_Capacity: 256 SSD
Monitor/Display Make & Model: Radeon 540 Graphics
Corel programs: Videostudio 2020 Pro
Post by rkstudio »
Hello,
I edited a video, then added the music and saved it as a project, but I thought the music track would be separate from the video. The music track isn't showing as a separate track, but it IS working.
Is that normal or did I do something wrong? I thought that when you save a video project, it saves it as separate tracks.
Re: Project has music but the track is not separate
Post by BrianCee »
I assume you can see the timeline music track and can confirm it is empty
If you saved the project as a .vsp file then the music is separate from the video and if you go "File >>open project" and select that project then it will appear as two items in the timeline
if on the other hand you saved the project by going to "Share" and selecting the computer icon then it will appear as one item only with music and video combined
rkstudio
Post by rkstudio »
Thanks Brian,
That worked. I think I opened it earlier by going to "insert media to timeline". I opened it the way you said and that was it. I guess I should have known that.
Thanks again,
Bob
