I have a video clip I made from Hudl.com of some of my daughter's volleyball that I want to use VS to clean up and do a little more with. I've been using VS for years but getting the video from Hudl is new and I feel the main culprit.
I take the entire file (and it is about 10m long) and put it in to a new project and the audio for each section has about 4 seconds of silence at the end of each. When I play the video, it is almost as if the audio is slightly sped up and that is why (although I could be imagining that). The odder thing is if I cut the video up into segments, it does not have that issue when I play it as a Clip but it does when I play it as a Project. Due to that, no matter what, the output copy will have the out of sync audio because it renders as a Project.
The original video stats:
- Length: 10:43
- Codec: H264 - MPEG-4 AVC
- Resolution: 1280x720
- Data rate: 3057kbps
- Frame rate: 29.225634
- Decode format: Planar 4:2:0 YUV
- Codec (Audio): MEPG AAC Audio (mp4a)
- Bit rate (Adutio) 96kbps
- Channels: Stereo
- Sample rate: 44100 Hz
- MPEG-4 Files
- 24 bits, 1280 x 720, 29.97 fps
- Frame-based
- H.264 Main Profile Video: 3057 Kbps, 16:9
- 44100 Hz, 16 Bit, Stereo
- MPEG AAC Audio: 96 Kbps
- VideoStudio: 19.5.0.35 (64bit Ultimate)
- Operating System: Windows 10 Home 64-bit
- CPU: Intel Core i5 4690 @ 3.50GHz
- RAM: 8.00GB Dual-Channel DDR3 @ 666MHz (9-9-9-24)
- Motherboard: Gigabyte Technology Co. Ltd. Z97M-DS3H (SOCKET 0)
- Graphics: 2047MB NVIDIA GeForce GTX 750 Ti (EVGA)
- Storage: 223GB Crucial_CT240M500SSD1 (SSD) // 1397GB Seagate ST31500541AS (SATA) // 232GB Samsung SSD 850 EVO 250GB (SSD)
- Audio: High Definition Audio Device
I've been using VS since X7 and this is the first I've run into the issue and I have a feeling it is due to the video I get from Hudl. Speaking of which, in case it helps:
- Original Video: https://www.dropbox.com/s/wobgx7wromcn4 ... L.mp4?dl=0
- Output from VS: https://www.dropbox.com/s/s139p1e3rrjmg ... p.mp4?dl=0
Any ideas on what I'm doing wrong? Like I said, I've been using VS for a few years and this is the first I've run across this problem.
