X9 Ultimate: Face tagging is not available
mk_frg
motherboard: ASUS2
ram: 16 GB
Corel programs: Paintshop Pro X9 Ultimate
Post by mk_frg »
Nature of the problem
Hi everyone,
After having worked with Serif PhotoPlus and Cyberlink PhotoDirector for quite some time I have decided to give it a try and use Paint Shop Pro X9 Ultimate.
Installation went fine. Update to version 19.0.2.4 (64-bit) also.
Here is my problem:
Trying to use "Find People" the three possible options (scan selected photos, scan current folder, scan subfolders) are simply grayed out and hence not available for clicking!
In addition, when I select a photo and try to use manual tagging under tab "people", it also doesn't work - it is not selectable and also grayed out!
I have contacted tech support and for three days I have received certain unhelpful e-mails every 24 hours or so. I had sent them an mp4-file showing the problem, but apparently they haven't really cared for this.
In addition, I have de-installed the program and re-installed it - with no better ending...
Has anyone here encountered a similar problem with face tagging not being available?
And what is wrong with this type of tech support? Are they always that slow - and not responding to the problem described? They even got detailed system information. But as I have mentioned before: I sent a mail, they "answer" within 24 hours, then I write back and have to wait another 24 hours... (Having used the chat support possibility, nice people tell me that they would inform tech support and that tech support would contact me asap...)
Hope someone knows what to do. I am getting desperate here - and haven't even started using the program yet.
Greetings from Germany,
Michael
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: X9 Ultimate: Face tagging is not available
Post by Jean-Luc »
Face tagging is available on my system (X9 64 bit).
Follow the EXACT steps described here :
http://help.corel.com/paintshop-pro/v19 ... eople.html
mk_frg
motherboard: ASUS2
ram: 16 GB
Post by mk_frg »
Thanks Jean-Luc for your help. I appreciate it!
In the end I have decided to continue using Serif and Cyberlink software.
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Post by MarkZ »
Random problems seem to occur with versions of PSP - I encountered a few with X9. A method that often clears up the simple ones is to reset the program. To do this, save the workspace and close PSP. Then press the shift key while starting the program and follow the prompts for returning to factory settings.
Mark
