Convert DivX file to DVD using MF4
gwoodall
I have a DivX video file that I want to convert to DVD to play on my home DVD player. Will MF-4 do that for me?
gwoodall
gwoodall@srv.net
gwoodall
gwoodall@srv.net
certain codecs are a crapshoot (imho). It might or might not work because divx and xvid videos can vary depending on who is creating them. You might be able to do the video, but not the audio (and vice versa).
This doesn't help you, but I just thought I'd mention up front that divx and xvid can be problematic...
Download the Trial to see if it will handle your files. But keep in mind, it might handle your current divx video, but not handle a different divx file...
George
heinz-oz
maddrummer3301
gwoodall
Thanks George; I guess I didn't provide enough info in my question: I already have MovieFactory 4 and when I tried to burn a DVD from a DivX file, it took over an hour for the progress line to show even 1% complete! So, thinking it wasn't converting the DivX file, I cancelled the program. I burned a DVD from the DivX file using Nero Express, but Nero apparently doesn't convert it to DVD because it won't play in my DVD player. However, I can play it on my computer! Any suggestions?GeorgeW wrote:certain codecs are a crapshoot (imho). It might or might not work because divx and xvid videos can vary depending on who is creating them. You might be able to do the video, but not the audio (and vice versa).
gwoodall@srv.net
gwoodall
Thanks Ploggy! I'll give it a try, if I can figure out where the "Export Movie" tool is!ploggy wrote:Try using the Export Movie tool to convert the Divx to MPGs. Its much faster than converting the divx to vob in the last step and usually has a higher success rate (imho).
gwoodall@srv.net
ChaChaCha
gwoodall
Yes, thanks George, I found the icon and successfully converted the DivX file to mpg. And actually, it didn't take all that much time, about 3 hours! Thanks to all who have helped me with this problem.GeorgeW wrote:it's one of those 4 icons in the bottom left corner (they go vertically next to the timeline down in the bottom left side).
gwoodall@srv.net
