Transitions: isolated to one object, not entire timeline?
brandon77
motherboard: Intel i7-4770
ram: 24 GB
Video Card: nVidia GTX 1070
Hard_Drive_Capacity: Chantilly
Monitor/Display Make & Model: Philips 27" Full HD (1080p)
Post by brandon77 »
I am trying to add the SMEAR Transition to an image I'm bringing in. However when I apply it to any single video track, the smear transition affects the whole timeline not just the single object/image I'm adding.
And yet other times I've been able to "isolate" the transition to just the object I want to use it on.
Is there actually a way to better control this? The alternative, besides luck, is having to create and render several 'layers' of timelines, and only applying the transition effect to the object after everything else is 'brought forward' and not impacted by it. (sorry for my wording, I'm not yet up to speed on the jargon).
Any ideas?
Thank you,
Brandon
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Transitions: isolated to one object, not entire timeline
Post by asik1 »
Brandon, you are not clear.
a screen shot might help us.
Panasonic X900m, VXF1
Post by BrianCee »
like asik I am not with you - you cannot put a transition in a timeline - transitions only go on either end of an image or across the join between two clips AFTER they are in the timeline - whatever I try I cannot do anything different
AussieTX
motherboard: Gigybyte 990FXA-UD3
processor: AMD FX8350
ram: 16 Gig
Video Card: Assus HD 7770 2GB GDDR5
sound_card: On Board Audio
Hard_Drive_Capacity: 2 T
Monitor/Display Make & Model: Asus 23" IPS + Acer 23" IPS
Post by AussieTX »
I think I see what Brandon is saying.
Place an image in the video track that about 10 seconds long
Now directly below it on an overlay Track place two images with a transition between them both.
Make sure both images on the overlay are smaller than the video track image so that you can see the Video track image at all times.
When played back the transition is applied to both the overlay AND the main video track.
What I believe he would like to see is the transition ONLY apply to the two images on the overlay track. See the screenshot below.
Jack of all trades,
Master of none!
If that's the case, then as we know, there are quite a few "overlay transitions" which work the way you describe, AussieTX, and would thus meet Brandon77's requirements. Unfortunately, though, Smear is not one of them. Look in the Transitions dropdown menu in VS for the Overlay Transitions category to see what is available.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
Aussie, this known bug I reported long ago, unfortunately it will never be corrected as it lie deep in the ulead core.
brandon77
ram: 24 GB
Post by brandon77 »
Thank you for the responses everyone. I'm sorry if I wasn't precise enough. AussieTX, yes that's exactly what I was trying to articulate (smear transition remaining local to the two objects it's affecting/not impacting whole timeline..)
Unfortunately it looks as if this has been a long-standing, never resolved issue. Oh well.
- Brandon
canuck
operating_system: Windows 8.1
Post by canuck »
You could create a separate project for the overlay.
Put the two images on the main video track and put the Smear transition between them. Make any adjustment and then save as a vsp project file.
Start a new project and put the background image on the main track. Then add the Smear project file on the overlay track and position it where you want
Now when you preview the project the Smear transition only applies to the overlay images and not to the main track.
This is a workaround but does work and is actually your alternative you mentioned in your initial post.
