Having recently upgraded from x7 to x9 I'm having issues with files created in x7.
The problem is that I have files with text on a curve that needs editing. As soon as I apply the change the text detaches from the path.
What am I doing wrong or what setting do I need to change?
PSP x7 vs X9 Text detaches from path when editing
Leehawnshee
- motherboard: Hewlett-Packard 229C 78.21
- processor: 2.40 gigahertz Intel Core i7-5500U
- Video Card: NVIDIA GeForce
- Hard_Drive_Capacity: 254.97GB
- Monitor/Display Make & Model: Generic PnP Monitor (15.3"vis)
- Corel programs: PSP X7, PSP X9
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
Re: PSP x7 vs X9 Text detaches from path when editing
X9 handles text differently than X7 and I found I had to do some testing and experimenting to get the sequence of steps correct for X9.
I created vector text on a vector curve in X7, saved as pspimage, opened the file in X9 and did not have a problem in adding to/editing the text and in modifying the curve it was on.
Edit: After writing this I experimented some more and found that after modifying a portion of the text, if i clicked on the check mark to complete the text jumped off the line. This happened a number of times. Then I found that if after modifying I clicked on a different spot in the text I was able to save it successfully. I did this a number of times with portions of the text, adding then changing font or colour and also when replacing all the text.
This definitely seems to be a bug in X9 but I need to do some more testing to see what sequence causes the text to detach.
Mark
