VS X9 - Explanation of function of all menu options
WAPMAN
motherboard: Dell 100 MHz
processor: Intel Core i7
ram: 4GB
Video Card: NVIDIA GeForce GTX 745
sound_card: NVIDIA High Def Audio
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Dell 19" Flat screen
Corel programs: Videostudio X9.5
Post by WAPMAN »
Where can i read about the function of all the various check boxes in the multitude of menu options in VS9
For example: Share - Disc - Setting & Options - Disc Template Manager - Project settings:
Two-pass conversion
Support X-disc
Field Type - upper or lower field first or no fields
What is the function of these last 3 options?
Re: VS X9 - Explanation of function of all menu options
Post by BrianCee »
Have you read all the help topics - - "Help >> Help topics"
Have you read the User Guide - - "Help >> User Guide (PDF)
WAPMAN
ram: 4GB
Post by WAPMAN »
Yes I have looked at the User guide - worse than useless.
Not enough detailed description of what boxes should be checked to carry out certain function etc.
Terfyn
motherboard: ASUSTeK P8H61-MX
processor: Intel Corei5-2320
ram: 8Gb
Video Card: NVIDIA GeForce 210
Hard_Drive_Capacity: 1000 Gb
Monitor/Display Make & Model: Acer & LG
Corel programs: VS X10 and PSP X8
Post by Terfyn »
It would be easier to decide on the process you want to carry out and then ask the question in this forum. The User Guide is perfectly OK but you need to know what you are looking for.
We all struggled in the early stages of using VS but the answers are here when you know what question to ask.
Davidk
ram: 16Gb
Hard_Drive_Capacity: 6Tb
Post by Davidk »
There's a clear pattern in the doco (user guide, help files) about a control - it exists, and what it does. What the doco doesn't say is how to use it, or provide examples. And I suspect that is really the sort of detail that you want. The only help available in that area is here (the forum - admin and users) but you need to be fairly clear about 1) your starting point, 2) what you want to do, or 3) the result you aim to get. Otherwise, it's trial and error.
There are a substantial number of on-line tutorials covering the 'how to' on the Corel's website, or on Youtube using Gripps as a search key. But again you need to have in mind the desired result and what controls may give it to use those sources effectively.
Davidk
