What is the closest effect to Premiere's Echo video effect?
TheListener
- processor: Intel Core i7-7500U CPU 2.70GHz
- Video Card: Intel HD Graphics 620
- Hard_Drive_Capacity: 256GB
- Corel programs: VideoStudio 2018 Ultimate
I'm a VideoStudio user, but have need of an affect similar to Premiere's Echo time effect. What is the closest effect in VideoStudio?
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Re: What is the closest effect to Premiere's Echo video effe
From within VSX9, highlight the music track, then select OPTIONS, then select Audio Filter, the audio filter box opens and all available filters are listed, you can select echo,long echo, reverb etc, play around with them to get the effect you want
Alternatively, you can use Audacity, apply the effects you want, then import into VS
TheListener
Unfortunately, the Echo effect in Premiere affects video, not audio. My question still stands as it relates to video.
Terfyn
- motherboard: ASUSTeK P8H61-MX
- processor: Intel Corei5-2320
- ram: 8Gb
- sound_card: NVIDIA High Def Audio
- Monitor/Display Make & Model: Acer & LG
- Corel programs: VS X10 and PSP X8
It may help if you explain exactly what you want and what "echo effect" in Premier does.
- RobertOZ
Extract from Adobe
One cool effect I learned recently with Adobe Premiere is “Echoing.” Just like sound, this tool makes it possible for the images in your video to “echo” within the film as a way to bring everything together in a meaningful and artistic way. At the very least, it will make your video look cooler.
It would appear that this effect is specific to Adobe
Terfyn
- ram: 8Gb
Perhaps the images could be put on one overlay track and combined using a degree of transparency to the overlay.
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Hi, If you go to FX>special > Strobe motion
You will find your starting point for a "look alike"
Panasonic X900m, VXF1
