Can't drop videos into track
csleep1958
- motherboard: ASRock 970M Pro3
- processor: AMD FX-4350 Vishera Quad-Core 4.2 GHz Socket AM3+
- ram: 8gb
- Video Card: XFX Radeon R7 250X R7-250X-ZNJ4 1GB 128-Bit GDDR5
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Asus - 27" IPS LED HD Monitor
- Corel programs: photo/video suite x6
Hello....I am trying to drop a video into a slideshow with no success. I have tried to drag and drop the video from my video library. When I attempt this, as I am dragging the video, there is a red circle with a sideways slash in it and nothing happens.... When I right click on the track and choose “insert video” I get a box that states “quicktime is required to open MOV files. Please download quick time from Apples official website. The videos are MOV files but play on windows media player when I open them...do I need to download quicktime for this to work? Also...all my videos are on another drive...but I don’t believe it’s the problem because I took it off the 2nd hard drive and placed the video on the desktop...I got the same results...thank you, Carol...
- aljimenez
- motherboard: Dell Inc. A08 4.16.2014
- processor: IntelCore i7-4790 3.60GHz 4Cores 8 Logical Proc
- ram: 24GB
- sound_card: AMD High Definition Audio
- Hard_Drive_Capacity: 500SSD+2TB
- Monitor/Display Make & Model: Three monitors, all Dell brand, one 4K
- Corel programs: Visual Studio, Paintshop
Re: Can't drop videos into track
Are you running Vs X6 as the panel on the right says? If this is so, you have a pretty old version and I won't be able to help much; you may need to install the correct version of Quicktime that that version expects and Quicktime is not a nice program to have installed (do a search to learn about this).
If you have X9, VS can take MOV files without needing Quicktime installed.
You can also use a conversion program to get that MOV file converted to something like mp4.
User for more than 10 years.
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Apple have stopped supporting QuickTime for Windows because of security issues, which affect QuickTime Player, the workaround is to download QuickTime 7, run as administrator, select MODIFY, then disable everything except QuickTime Essentials, then install, this will only install the codecs and VSX6 will now be able to play .MOV filescsleep1958 wrote:Hello....I am trying to drop a video into a slideshow with no success. I have tried to drag and drop the video from my video library. When I attempt this, as I am dragging the video, there is a red circle with a sideways slash in it and nothing happens.... When I right click on the track and choose “insert video” I get a box that states “quicktime is required to open MOV files. Please download quick time from Apples official website. The videos are MOV files but play on windows media player when I open them...do I need to download quicktime for this to work? Also...all my videos are on another drive...but I don’t believe it’s the problem because I took it off the 2nd hard drive and placed the video on the desktop...I got the same results...thank you, Carol...
csleep1958
- ram: 8gb
Thank you everyone...I forgot to say in my post that yes, I am running VS x6.....
csleep1958
- ram: 8gb
Thank you all for your input...well, after some research it looks like Quicktime 7 is unsafe...as stated above
. So it seems I am not going to be able to add video to my slideshow....unless someone has another workaround???? Simple if possible as I am not very computer savvy.
I would have never bought this version if I knew I would not be able to use video clips, what a waste! Very frustrating as I have a beautiful slideshow I just made for my MIL's 80th who I told I would revise and add the videos and pictures I took at her party and add to it...again, any other workarounds appreciated if possible!! Thanks...
Just convert the .mov clips to either DVD-compatible mpeg-2 or high def mpeg-4 which will have the same or very similar properties to the .mov files. Quite a few of us here use a free video converter called Format Factory which you can easily find with a Google search. Just be careful when installing it to read each page of the installation routine to avoid installing other bloatware programs which are offered.
csleep1958
- ram: 8gb
Mr. Berry/Al jimenez....thank you so much for the converting suggestion...seems like the only solution...that seems simple and that I can handle
I will check into Format Factory as suggested...Thank you everyone for your time to help me with my issue...have a good evening!! Carol...
