Capture problem - DVDWS thinks my drives are FAT32
uleadgator
Post by uleadgator »
I have used 2 different cameras on three different computers. It is not the hardware I am using. I have captured to a computer with a single hard drive and computers with multiple hard drives.
When I capture (transfer) a DV tape to the hard drive, file sizes are limited to around 4GB each.
When I repeat the capture process using Microsoft MovieMaker, I can capture 40 minutes of AVI in one big 9 GB file, not the three split files that ulead produces.
uleads tech support swears it is my machines, not their software.
Has anybody else had this problem? workarounds?
Windows XP all updates
Athlon Processors
1GB RAM
80GB C:
250GB capture drives
DVDWS 2.0 with all patches
All hard drives were reformatted when purchased to the NTFS format
Thanks.
johnpr98
Post by johnpr98 »
Hi uleadgator :roll:
It's a type 2 issue IMO
Use type 1 & Scene detection off
I just captured 52 mins in XP, 1 one video of 11GB approx, 1 chapter
DVDWS 2 default is type 2 & Scene detection On.
Type 1 & Scene detection Off for one continous file.
Type 1 selection seems to stick, however Scene detection ticked On is alwas the default for a new project :evil:
Regards
uleadgator
type 1 capture - same problem
John,
I just finished using type 1 capture with scene detection off.
I still have the same problem.
Ulead is limiting my capture file size to FAT32 limits (4GB).
Any other suggestions?
Thanks.
johnpr98
Post by johnpr98 »
My type 1 capture experiment this morning worked for me fine
Do you have any other editors installed that's over ruling type 1 capture
Roxio Videowave?
btw I'm in PAL land so I can't speak for NTSC
uleadgator
I tried it again (type 1) still doesn't work.
I have been reading a few other forums and this appears to have been an ongoing problem for over the past year.
chinito
Post by chinito »
Hey, Gator.
I had the exact same problem but with VS9. I upgraded from VS8 (which was able to capture 1hour long video files at about 19GB+/- no problem) and then I upgraded to VS9, which thought I was FAT32 and wouldn't capture anything bigger that 4GB. Didn't change anything else. If you look where you installed DVD WS I bet you're going to find multiple WS folders, one for each install attempt. Anyway, here's email I got from Ulead regarding Uninstalling/installing VS9. I did the steps and VS9 started saving files bigger that 4GB. Perhaps it will give you a clue to DVD WS? Good luck!
1) Clean up C:\Windows\temp directory. Clean up all files in C:\Documents and
Settings\[UserName]\Local Settings\Temp folder. Uninstall VideoStudio 9 from
control panel Add/Remove programs.
Delete following folders
=>C:\Documents and Settings\All Users\Application Data\Ulead Systems\Ulead
VideoStudio
=>C:\Documents and Settings\All Users\Application Data\SmartSound Software Inc
=>C:\Documents and Settings\[Username]\My Documents\Ulead VideoStudio
=>C:\Program Files\Common Files\Ulead Systems\
Proceed to step 2, even if you can't complete step 1.
2) Delete folder {88F92798-59AB-474F-B40D-1EC5F782F7EE} in
C:\Program Files\InstallShield Installation Information (Please set "Show hidden
files and folders." in folder option in OS)
3) Please del the folder " Ulead VideoStudio 9.0" folder in C:\program
files\ulead system
4) Run Regedit from Start/Run in Windows task bar
5) Delete folder {88F92798-59AB-474F-B40D-1EC5F782F7EE} in
KEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\
(If you always see Ulead VideoStudio 9 file name showed in the Add/Remove
Program, please do point 5)
6) Then reinstall UVS 9 again
Hey, what do I know - it worked....
johnpr98
Post by johnpr98 »
1. Are you sure you are saving to an NTFS drive?
2. Are you PAL or NTSC?
3. By all means uninstall & reinstall DVD WS, remove:
DVD Workshop
Documents and Settings\Your Name\Application Data\Ulead Systems\Ulead DVD Workshop
4. Do you have any other Video Editors Installed?
Regards
johnpr98
Post by johnpr98 »
UPDATE
I've just captured 5GB with type 2 OpenDML in XP
The type 2, 4GB issue seems to effect my Win 2K system for some reason?
Do your type 1 properties look like mine? (Swap PAL for NTSC if relevant?)
Typos edited
johnpr98
Post by johnpr98 »
UPDATE
The type 2, 4GB capture limit in Windows 2000 was caused by
MainConcept DV Codec 2.4.4 -- type 2
I uninstalled this in Add Remove programmes & I can now capture over 4GB with type 2 OpenDML & PCM audio.
The 4GB limit problem is caused by a rogue codec installed on your system, over ruling/messing up the MS DirectShow codec.
Regards
uleadgator
uleadgator - update
Sequence of events to date:
First of all, thanks to everybody for their suggestions.
Johnpr98 – It was not a type 2 issue on my machines, I do have a cyberlink video editor installed on my machine.
Chinito – I downloaded the trial version of VS9 and it captured one big file. I uninstalled VS9 and installed a copy of VS7se that came with a DVD burner, it also was able to capture one big file. No adjustments to either program were required.
Note: I am not able to burn a SVCD at the same time I render it. Ulead suggested I make some registry changes, I did the changes and DVDWS would not operate correctly. I will save this issue for another day. I am rendering in one step, closing the program, and burning in another step.
John – All my drives are NTFS, I format them after I install them, I am NTSC, I do not fully understand what OpenDML means. I did download and install a freeware program that lets me know what codecs are installed on my machine http://www.headbands.com/gspot/
John – I am running XP not W2k
Here is where I am at currently.
I contacted Ulead tech support and they emailed me a link to FTP another full version of DVDWS. I have uninstalled all Ulead products from my machine, cleaned the registry out, performed a disc cleanup and I am now defragging my drive.
After I install the FTP version of DVDWS I will give you an update.
Thanks again.
AMD athlon 2800+
on board generic video card
on board firewire
1GB RAM
80 GB boot drive
2 250 GB capture/archive drives
Windows XP
Canon GL1
johnpr98
Post by johnpr98 »
Using DVDWS2 I can record over 4GB with XP & Windows 2000 using type 1 or 2 DV OpenDML
(OpenDML AVI is the Microsoft codec that is part of DirectX & does not have a 4GB filesize limit).
Your Cyberlink programme is an unknown too me, hopefully the new installation will fix this issue for you by over ruling the rogue codec?, if not please read the bold text again :roll:
See the picture in my Sun Aug 14, 2005 9:34 pm post for the correct file properties, I don't think your DVDWS captured video properties are the same, are they?
Regards
uleadgator
I can't figure out how to add an image to this message.
All my properties are the same as yours, except the PAL vs. NTSC.
Capture failed again to save one big AVI file in Type 2, I will try Type 1.
Still breaking it up according to FAT32 standards.
AMD athlon 2800+
on board firewire
1GB RAM
80 GB boot drive
Windows XP
Canon GL1
uleadgator
gspot gives me this information.
- - ** Problem ** ** File Missing: C:\Program Files\Common Files\Ulead Systems\MPEG\ulDVDVideo.ax
- - ** Problem ** ** File Missing: C:\Documents and Settings\d\Desktop\CEVideo.ax
AMD athlon 2800+
on board firewire
1GB RAM
80 GB boot drive
Windows XP
Canon GL1
uleadgator
fixed all but one with MFse reinstallation
DMO WMVA WMVideo Advanced Decoder DMO Microsoft Corporation qasf.dll --> wmvadvd.dll
DMO MP4S Mpeg4s Decoder DMO Microsoft Corporation qasf.dll --> mp4sdmod.dll
DMO WMV Screen decoder DMO Microsoft Corporation qasf.dll --> wmsdmod.dll
DMO WMVideo Decoder DMO Microsoft Corporation qasf.dll --> wmvdmod.dll
DMO DMO JPEG Video Decompressor Roxio, Inc. qasf.dll --> JPEGDecompressor.dll
DMO MP43 Mpeg43 Decoder DMO Microsoft Corporation qasf.dll --> mp43dmod.dll
DMO MPG4 Mpeg4 Decoder DMO Microsoft Corporation qasf.dll --> mpg4dmod.dll
DSH DV Video Encoder qdv.dll
DSH Indeo® video 5.10 Compression Filter Intel Corporation ir50_32.dll
DSH MJPEG Compressor quartz.dll
DSH Roxio MPEG1 Video Encoder Roxio, Inc. RoxioVideoMPEG.dll
DSH MPEG2 Roxio MPEG2 Video Encoder Roxio, Inc. RoxioVideoMPEG.dll
DSH MPEG1 MPEG Video Decoder quartz.dll
DSH MSS1 Microsoft Screen Video Decompressor Microsoft Corporation msscds32.ax
DSH WMV1 Windows Media Video Decoder Microsoft Corporation wmvds32.ax
DSH WMV2 Windows Media Video Decoder Microsoft Corporation wmv8ds32.ax
DSH MP43 Microsoft MPEG-4 Video Decompressor Microsoft Corporation mpg4ds32.ax
DSH DVSD DV Video Decoder qdv.dll
DSH MPEG1 Ulead DVD Video decoder 2 ** File Missing: C:\Program Files\Common Files\Ulead Systems\MP
DSH MPEG1 Ulead DVD Video decoder Computer & Entertainment, Inc. CEVideo.ax
DSH MPEG2 Roxio MPEG2 Video Decoder Roxio, Inc. RoxioVideoMPEG.dll
DSH IV41 Indeo® video 4.4 Decompression Filter Intel Corporation ir41_32.ax
DSH IV50 Indeo® video 5.10 Decompression Filter Intel Corporation ir50_32.dll
DSH MJPG AVI Draw quartz.dll
DSH CyberLink MPEG Decoder CyberLink Corp. clmvd.ax
DSH Video Port Manager quartz.dll
DSH AVI Decompressor quartz.dll
DSH QTRpza QT Decompressor quartz.dll
DSH MJPG MJPEG Decompressor quartz.dll
DSH CL Video/SP Decoder (Roxio) CyberLink Corp. clvsd.ax
DSH CyberLink Video/SP Decoder CyberLink Corp. CLVSD.ax
VFW CVID Cinepak Codec by Radius Radius Inc. qcap.dll --> iccvid.dll
VFW I420 Intel 4:2:0 Video V2.50 Microsoft Corporation qcap.dll --> msh263.drv
VFW IV32 Intel Indeo(R) Video R3.2 qcap.dll --> ir32_32.dll
VFW IV41 Intel Indeo® Video 4.5 Intel Corporation qcap.dll --> ir41_32.ax
VFW IV50 Indeo® video 5.10 Intel Corporation qcap.dll --> ir50_32.dll
VFW IYUV Intel IYUV codec Microsoft Corporation qcap.dll --> iyuv_32.dll
VFW M261 Microsoft H.261 Video Codec Microsoft Corporation qcap.dll --> msh261.drv
VFW M263 Microsoft H.263 Video Codec Microsoft Corporation qcap.dll --> msh263.drv
VFW MP42 Microsoft MPEG-4 Video Codec V2 Microsoft Corporation qcap.dll --> mpg4c32.dll
VFW MPG4 Microsoft MPEG-4 Video Codec V1 Microsoft Corporation qcap.dll --> mpg4c32.dll
VFW MRLE Microsoft RLE Microsoft Corporation qcap.dll --> msrle32.dll
VFW MSVC Microsoft Video 1 Microsoft Corporation qcap.dll --> msvidc32.dll
AMD athlon 2800+
on board firewire
1GB RAM
80 GB boot drive
Windows XP
Canon GL1
johnpr98
Post by johnpr98 »
I'll wait for this update, fingers crossed ;)
Didn't spot a rogue in your list, Roxio MGI has been on my hit list previously, your Roxio codecs seem to be MPEG related.
Regards
