Spiral type logo "Dreamcast Sega"
JohnPSPX92891
- motherboard: M5A78L usb3
- processor: AMD FX6100
- Video Card: ATI Radeon 4800
- Hard_Drive_Capacity: 300GB
- Monitor/Display Make & Model: Philips 193V
- Corel programs: PaintShop Pro Ultimate X9
Hello anyone knows a way for producing a spiral-type logo like the "Sega Dreamcast" one
Cassel
- ram: 16Gb
- Corel programs: PSP 8 (JASC) to PSP 2023
Re: Spiral type logo "Dreamcast Sega"
Did you try the Effects > Distorsion > Twirl?
Run it with the maximum value and run it a second time on a straight line going from the center of your image to the edge.
It might not be exactly what you are looking for, but maybe enough for what you need?
Cassel
https://scrapbookcampus.com
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
On another board Trev created a script that would draw a raster spiral (not vector) using the paintbrush. It was written for Jasc's PSP 8.1 (and works in 9 also) but doesn't work in my X7 because it throws an error. I suspect the error is caused by a deprecated command in the script, and perhaps somebody can figure out how to correct it for newer PSP versions. If interested, here's the link to the page with Trev's script:
http://www.talkgraphics.com/showthread. ... w-a-spiral
JoeB
Using PSP 2019 64bit
JoeB
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
What error do you get? The error I get is that the range() command (a Python command) requires an integer but got a float and should be a fairly straightforward fix. All we have to do is change this line from this
to this
int(decimal) converts a decimal (float) into an integer.
Code: Select all
for N in range(0, Max):Code: Select all
for N in range(0, int(Max)):https://levifiction.wordpress.com/
JoeB
- ram: 8 GB
Yep, that was the error. And I'll be honest. When I posted this I kind of hoped you'd consider figuring out a vector spiral script.LeviFiction wrote:What error do you get? The error I get is that the range() command (a Python command) requires an integer but got a float and should be a fairly straightforward fix. All we have to do is change this line from this
to thisCode: Select all
int(decimal) converts a decimal (float) into an integer.Code: Select all
And by the way, I assume that, for some reason, PSP 8 and 9 don't require the int(Max)) syntax? Is that because of changes in the Python library or something since years ago when the script was created by Trev?
JoeB
JoeB
Cassel
- ram: 16Gb
I noticed that in PSP9, it does show the error in the SOP yet, it continues without a problem. I guess it was just not as picky back then!And by the way, I assume that, for some reason, PSP 8 and 9 don't require the int(Max)) syntax? Is that because of changes in the Python library or something since years ago when the script was created by Trev?
Cassel
JohnPSPX92891
Thanks you for the answers...
JohnPSPX92891
Hello, I am writing again on a spiral restiligne that I could find on the Web. Indeed, the latter eventually stop. So demadais me if there were not a function or an extension to continue the logic of the rectilinear spiral tracet recovered. In thanking you sincerely in advance ...
Kathy_9
- Hard_Drive_Capacity: 2TB
Does the script in this thread help you? http://forum.corel.com/EN/viewtopic.php?f=104&t=60247
