I make a picture slideshow, is there a way to change the length of each picture.
Also is there a Pro and a non pro version in x6?
VS x6 how to modify the length of each picture
Re: VS x6 how to modify the length of each picture
If you want to change the duration of each photo individually just double click on the image in the timeline and change the little clock in the panel which opens
if you want to change the length of all of them at the same time - click on the first one in the time line then hold down shift when you select the last one - all will then show as selected - RIGHT click on the selection and choose "change photo duration" in the pop up - then adjust the little clock which appears
to make them longer when you insert them change the default in "settings >> preferences"
I don't remember the options in X6 but I don't think there was a non-pro version I think there was a pro and a pro- Ultimate but you cannot change what you have - but the actual programme is identical in each version - you just got more free plug-ins with the Ultimate
asterix
Thanks BrianCee
