What is the best way to make a stop-motion video?
rkstudio
motherboard: There is no motherboard listed
processor: Intel Core i7-855ou CPU 1.80 GHZ
Video Card: Radeon 540 Graphics
Hard_Drive_Capacity: 256 SSD
Monitor/Display Make & Model: Radeon 540 Graphics
Corel programs: Videostudio 2020 Pro
Post by rkstudio »
I want to make stop motion videos, but I'm undecided as to making it with many photos, or making a video and clipping it. I would appreciate some opinions as to the best way to do this. I know both methods have pros and cons, but a general consensus would be nice.
I'm making a test with the method of many photos, but I'm not sure of the best way to get them into VS. Does it need to be one at a time? It seems like that would be very time consuming.
BTW, I'm using VS Ult. pro x9.
Thanks.
Terfyn
motherboard: ASUSTeK P8H61-MX
processor: Intel Corei5-2320
ram: 8Gb
Video Card: NVIDIA GeForce 210
sound_card: NVIDIA High Def Audio
Hard_Drive_Capacity: 1000 Gb
Monitor/Display Make & Model: Acer & LG
Corel programs: VS X10 and PSP X8
Re: What is the best way to make a stop-motion video?
Post by Terfyn »
I presume your photos are in a folder on your PC. As they will be separate files, you can use "Import from Digital Media" in the Capture section to import the whole Folder.
Stop Motion is creating animation from inanimate objects by changes in movement captured in a shot of one or more frames.
The whole process is included in the VS software and you do not need to make external photos. The process will make the video for you and all you will need to do is add the sound. You will need a suitable camera that VS recognises plugged into your PC.
I use a HD Webcam aimed at my "set" on a table and compare the changes in motion using the "Onion Skin" effect, I normally keep the frame settings to the default of 5.
I suggest you read the User Manual p225.
rkstudio
Post by rkstudio »
Thank you very much for the information. I will try it out tomorrow since it is late here now. I have a canon sx40 hs camera, but I dont' think it's one that VS will work with. I'll try it again though.
Thanks again.
