playback on timeline stops
websister
processor: intel core i51.7ghz with turbo boost up to 2.7ghz
ram: 1000 gig
Video Card: intel hd grapics 4400 up to 1790 mb Nvidia
Hard_Drive_Capacity: 719 gigs
Monitor/Display Make & Model: acer laptop aspire E15
Corel programs: corel video studio x8 and x9
Post by websister »
hello,
me again, well i was editing quite fine when i was starting a new song on the timeline and videos. the yellow line just above the videos stops and no matter what i do it will not go beyond that point. how to fix it? thanks
ps i changed the format of music from mp3 to wav file and put in same folder as the other music but it did not make a difference.
"Change the way you look at things and the things you look at will change"
Re: playback on timeline stops
Post by BrianCee »
could that yellow line be more orange perhaps ?
you have set a mark out point - select 'Project' mode and immediately under the preview screen you should see a white line with two orange sliders under it - using the mouse cursor slide the right end one to the very right hand end of the line - if the orange line is then still there move the left hand end one to the extreme left end of the line as well which should then make the line vanish
websister
ram: 1000 gig
Post by websister »
yes, that line was orange, lol, well I did what you advised and it worked i don't know this program that well, I am learning as I use it. I used to use adobe premire pro but they charge per month now for use. so many different things to do compared to adobe,but I do like this program and hope to learn it.
Hi websister
The Orange line is the Preview Playback Range, you are not alone usually we find this by mistake, trying to trim a clip but have preview set.
Once set we can play the selected area as project playback, we can also render / convert that selection using Share – to the bottom of the panel is the option to select “Create Preview range Only” can be useful.
View this web page for more details you may find useful
http://lata.me.uk/corel/trimbar/trim_bar.htm
