So, i was asked back in 2015 if I knew of a good procedure to create an anaglyph (Red/Cyan 3D) effect similar to the one in this tutorial: http://www.howtogeek.com/69368/how-to-m ... any-image/
So I made this script, but then I saw Corel is selling a new Anaglyph script for $10. Couldn't let that stand, so while I know nothing of how they've done their effect. I've decided to update this script with some more options and to do the effect slightly differently.
When you run the script it asks you for the color combo you want to use (red/cyan, green/magenta, blue/yellow), and then asks for the shift value (changes based on the size of your image) and then does all of the hard work for you. The result is a new layer with the effect applied, you can use this on any layer in your image, or on the image as a whole. This allows you to follow the tutorial listed above and give different shift values to the foreground and background.
Here's the link to the script on my Google Drive:
https://drive.google.com/file/d/0B8FlFLNbvRNecmdkMzVhWlZReEk/view?usp=sharing
Example:
Anaglyph - 3D effect (not real 3D)
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Re: Anaglyph - Red/Cyan 3D effect
Interesting. I downloaded the script but will wait until I have some 3D glasses to test it.
JoeB
Using PSP 2019 64bit
JoeB
- ram: 6 GB
I kept my glasses from when I was a child. At best it creates a slight parallax effect but not much else. xD
JoeB
- ram: 8 GB
Then I don't think I'll be rushing out to get a pair anytime soon.LeviFiction wrote:I kept my glasses from when I was a child. At best it creates a slight parallax effect but not much else. xD
JoeB
JoeB
- ram: 6 GB
Re: Anaglyph - 3D effect (not real 3D)
I've updated the script above. This was more or less in direct response to seeing Corel's Anaglyph script being sold for $10 by offering a cheaper alternative (free). I've improved the script in the following ways:
1) You can now choose from multiple color combinations)
2) The Shift value is calculated from the size of your image (roughly 20 pixels per 1000 pixels wide)
3) The effect is all done in image, no more splitting and combining images.
4) You can now perform the effect on an individual layer, or on the entire merged document if you have multiple layers.
5) Just like before, the result is a new layer so it's non-destructive.
Radim
- ram: 4GB
- Monitor/Display Make & Model: 27 inch
I compared those two scripts.
But I lost my glasses.. so can't say difference.
https://www.upload.ee/files/15559688/co ... n.zip.html
- ram: 6 GB
As noted with JoeB perviously, since you're using a flat image, you can't actually create a 3D effect (not without something to invent data that doesn't exist anyway). So 3D glasses won't do much, though occasionally you can get a neat parallax effect, making it look like a cardboard cut-out. But the main point of this effect is the final look, not it's usefulness for 3D.
Thank you for posting the comparisons, this shows that my script and the official one are essentially doing the exact same thing. The biggest differences I can see are: 1) I'm merging the result, 2) I'm using the 'Screen' blend mode and they're using 'Lighten', 3) They also crop the the image after moving the layer to get rid of that hideous sidebar that's created. I leave that to the user to do.
When I get home I'll add the option to turn off merging the resulting group. That way people can play with the result and to get something they like better.
