Image > Free Rotate Crashes PaintShop Pro X9
Dypsis
motherboard: GIGABYTE X299X DESIGNARE 10G
processor: Intel Core i9-10900X
ram: 64 GB
Video Card: GIGABYTE GeForce GTX 1660 Super Mini ITX 6 GB OC
sound_card: Realtek ALC1220
Hard_Drive_Capacity: 17 TB
Monitor/Display Make & Model: Samsung 27" FHD LED FreeSync Gaming Monitor
Post by Dypsis »
If I open an image, then go:
Image > Free Rotate and change the direction from right to left with the radio button, PaintShop Pro X9 Update 1 v19.0.1.8 crashes every time.
Is there a fix coming for this?
OS: Windows 10 64-bit.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: Image > Free Rotate Crashes PaintShop Pro X9
Post by hartpaul »
This has already been mentioned in the thread with the vague title :
Corel PaintShop Pro X9 - A big disappointment!!
http://forum.corel.com/EN/viewtopic.php?f=56&t=60017
Dypsis
ram: 64 GB
Post by Dypsis »
hartpaul wrote:This has already been mentioned in the thread with the vague title :
That's why I gave it a proper title.
o0spyder0o
motherboard: Asus P8z68 Gen 3
processor: Intel I7 2700k
ram: 12 gb
Video Card: Asus GTX 970 4gb ram
sound_card: Realtek HD audio
Hard_Drive_Capacity: 1tb
Monitor/Display Make & Model: Asus VE248
Corel programs: VS Ultimate X7/X8/X10 : PSP Pro X9
Post by o0spyder0o »
Just tried it after reading about it here and mine crashes when I click the button to try rotating. All ok on the preset rotations. The code appears to be breaking as soon as you click the free rotation so it's not the actual rotation breaking it but a jump to whatever routine is managing this.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
Sounds to me like something that Corel should be working on for a fast second patch.
JoeB
Using PSP 2019 64bit
Dypsis wrote:If I open an image, then go:
This issue has been escalated to Corel
"Is there a fix coming for this?" -- i guess yes????
Zantara
processor: i5-2100 3 10 Ghz
ram: 12Gb DDR4
Video Card: Intel UHD graphics 620
Hard_Drive_Capacity: 256SSD 1TB
Corel programs: From PSPX2 to PSP2022
Post by Zantara »
There seems to be a solution.
* Find Corel PaintShop Pro X9.exe in C://Program Files(x86)/Corel/Corel PaintShop Pro X9/
* Right mouse-click > Properties
* Tab Compatibility > Compatibility Mode > Make it Windows 7 compatible
* Open with Administrator rights by rightclicking the exe again.
Worked for me.
Must have started coding on X9 when Windows 7 was still fashionable.
Hi Zantara
Thanks for the info, unfortunately that does not work for me.
I have also re-installed the program and running the unpatched version 19.0.0.96
By the way I have the same issues running 32 bit and 64 bit programs.
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
I'm getting the crash and I'm running Windows 7 Professional.
Dypsis
ram: 64 GB
Post by Dypsis »
lata wrote:This issue has been escalated to Corel
Great! :)
Batka
Corel programs: PSPX8, PSPX9
Post by Batka »
My PSPX9 *.pspimage jobs, which contains free rotated text elements are unopenable after saving..
Free rotated pictures works, just the rotated text contain a bug.
JoeB
ram: 8 GB
Post by JoeB »
Batka wrote:My PSPX9 *.pspimage jobs, which contains free rotated text elements are unopenable after saving..
There are two important points in the quoted post. First,, @Batka is able to use Free Rotate without it crashing PSP, which most people don't seem to be able to do. Second, he does have an issue when he does use free rotate on text in that PSP fails to open those images once saved. So there would seem to be some connection between the free rotate issue and the issue some people are having with X9 not opening some image.
However, if the only problem with opening some saved images is when they have text that has been free rotated then that would either mean that those people reporting not being able to open some images ARE able to use free rotate without crashes, or else there is another issue also causing some images not to open.
EDIT: Joelle, in another thread, reported that Free Rotate doesn't crash her X9, so it's now starting to look as if it might depend on OS plus some other system configuration and/or specs. Definitely not just an OS issue for sure based on the posts.
Very confusing at this stage.
JoeB
Midnight
processor: 4 core I7
ram: 18 gig
Hard_Drive_Capacity: 1 T
Monitor/Display Make & Model: phillips 27"
Post by Midnight »
Whe are running a paintshop pro forum for many years ... There are members even from different Countrys ... Different OS ... Different setups ! Different filters !!
Everything is different !!!!!
Just one litle thing is common ...
All of us .. Whe cannot even touch this free rotating radiobutton !!
Yes ...... you can free rotate !! if you do not try to change the value in it !
This is a major bug ..... You cannot bring this problem on a OS or a setting !!!!
This is not a setting or OS problem !!
In all the other vesions of Paintshop pro this function is working fine ! Why Changing this script ??
Regards Midnight
I know .. i'm a Flemish guy .. My English is not that good ...
JoeB
ram: 8 GB
Post by JoeB »
Midnight wrote:Whe are running a paintshop pro forum for many years ... There are members even from different Countrys ... Different OS ... Different setups ! Different filters !!
Your English is fine - I don't speak any other language at all! :-)
I wasn't trying to say it was an OS issue. I agree it is a PSP issue, but am just suggesting that because the issue doesn't affect everybody then it still may only become evident when some other system or program or registry settings are also present.
JoeB
Cassel
ram: 16Gb
Corel programs: PSP 8 (JASC) to PSP 2023
Post by Cassel »
Interestingly, i got ONE crash initially, then could not replicate it.
I tested many combo and found this (using Windows 7):
- on a 32 bit machine, i can't replicate the crash at all
- on a 64 bit machine, using the 64 bit version of PSP, i got one crash initially, but could not replicate it after.
- on a 64 bit machine, using the 32 bit version of PSP, i got crashes after crashes
for me, it didn't seem to happen when i clicked on something in particular, but almost seems like it is happening seconds after doing something else, like if i change the settings slowly, the crash will happen not immediately upon clicking on something.
As JoeB mentioned, there is probably a specific combo of OS and other machine configurations that would be the common denominator (in addition to PSP obviously).
Cassel
https://scrapbookcampus.com
