Install issue
dndrja0
Install issue
Post by dndrja0 »
Trying to install on hp2370 windows10 64 bit laptop. Select directory to install shows only top 1/4 install screen displays in centre of screen .Continue /install. / cancel buttons not visible. Installation not possible. Left message on chat board but no response.
:!: Not good service!
Dutchmm
operating_system: Linux
System_Drive: N/A
motherboard: Asus 97
processor: Intel i7 4785T
Video Card: Onboard Intel
sound_card: Intel AC97
Hard_Drive_Capacity: 2.5TB
Monitor/Display Make & Model: Philips 28"
Corel programs: ASP 3 Pro (and 2 and 1 before)
Re: Install issue
Post by Dutchmm »
Even if you cannot see the OK and cancel buttons, they will still be there. This means that you can move the cursor onto them (in technical terms, give them focus) using the Tab key. Each press of the key will move the cursor forward one button, and each shifted tab back one. Then press Enter actually to "click" the button. I do not remember the order of the installer buttons, but you should be able to find the right one by trial and error.
Hope this helps
hdrabkin
Corel programs: Paintshop Pro x9, Aftershot Pr
Re: Install issue
Post by hdrabkin »
Was looking for this post. Thank you thank you Dutchmm. THAT was the problem. This also worked with the ParticleShop Installer.
