Return Crop Tool Position
Dave_SMR
motherboard: FOXCONN A76ML-K 30 1.0
processor: Athlon II X4 640
Video Card: ATI Radeon 3000 Graphics
Hard_Drive_Capacity: 250GB
Monitor/Display Make & Model: Hanns.G HL225D x 2
Corel programs: PSP X7 / VS X8
Post by Dave_SMR »
I have a script that starts from a user set crop area, applies the crop and adds some borders. I'd like to know the offset of the defined crop area when it first runs. Is this possible?
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Return Crop Tool Position
Post by LeviFiction »
Yes and no. Mostly no. xD Yet more fun with PSP scripting. PSP rarely has any access to current at the moment information about the state of the program. The active location of a tool for example is not known.
Now, if they have applied the crop before then you can grab the previously used settings and use those. But that's about it.
So, if you tell your user to set the crop, apply it and then undo the crop you can find out what that value was.
Dave_SMR
Post by Dave_SMR »
That could be useful. How do I grab those previously used values?
ram: 6 GB
This is taken the AddBordersAndSelect Script.
Code: Select all
    # now call GetCommandInfo to extract the last used parameters.
    Info = App.Do(Environment,  'GetCommandInfo', {
                'TargetCmd': 'AddBorders',
                'ParamInfo': App.Constants.ParamInfo.LastUsed
    # command parameters are stored in a key consisting of library name and command name
    CmdParam = Info[ 'Library' ] + '\\' + Info['Name']
    Params = Info[CmdParam] # get a simpler dictionary to work with
Just change the 'TargetCmd' parameter to the command you want to get the last settings of. And Params will hold a dictionary of all of the parameters.
