I don't think that the bars should be there at all.
(and I don't have any mod file in my test folder
Then you are using the wrong filter, there are 2 available filters, "Crop Boarders" and "Cropping", the one to use is Cropping and all you need to do is grab the centre yellow handle on each side and move it across to the where the black boarder starts on the videoDavidk wrote:The clip is a whole 8sec and 11Mb long, and I was about to upload to OneDrive when I read the latest posts.
And the cropping filter indeed it does remove the black borders from the rotated clip image. But it took a bit of experimenting to establish how this filter works - other filters use sizing handles, with this one, you need to play with the percentages (height and width) until the crop border matches the outline you want. And once found, right click and copy to all key frames markers to make sure that the black zone does not come back as the clip plays.
Thanks all.
Davidk
asik1 wrote:But still David , upload that clip .
(and I don't have any mod file in my test folder)
lata wrote:Hi
another option would be to render the original 720 x 576 to a 1920 x 1080.
Then using the new 1920 to rotate, no borders.
Whatever you do the video will display as a smaller vertical panel, (portrait view)
OH... OK did so.lata wrote:asik1 wrote:But still David , upload that clip .
Asik you can create your own sample, the extension is irrelevant, it an anamorphic video 720 x 576 x 16:9
Take any video, make sure it fills the screen so a 1920 x 1080 will do.
Render that to Mpeg2 720 x 576. That is your sample.
now use that in the overlay track, and rotate.
