VS X95 Failed to Initialise
Locked
MDBuc
motherboard: Z87-G55
processor: 3.50 gigahertz Intel Core i7-4770K
ram: 16 GB
Video Card: NVIDIA GeForce GTX 760
sound_card: NVIDIA Virtual Audio Device
Hard_Drive_Capacity: 4000000000
Monitor/Display Make & Model: Samsung SyncMaster
Corel programs: Video Studio X95
Post by MDBuc »
I installed VS X95 (VS X5.0, X7.0, X8.4 already installed). When VS X95 is launched, it takes long time (3-4 mn) and then says "Get All items failed, result = 100". Shall I de-install the previous versions of VS.? Personnaly, I'd like ensuring that X9.5 works before removing previous versions.
Thanks for advice,
Re: VS X95 Failed to Initialise
There is no need at all to remove the past version(s). Quite a few of us here have several versions installed, with no problem.
I have to say that I don't recall ever seeing such an error message in all my years on this Board. All I can suggest is that you uninstall X9.5 and reinstall it.
MDBuc
ram: 16 GB
Post by MDBuc »
Dear Ken,
I did it but it does not solve the issue. Is a log available somewhere or a tracing I could enable?
Best Regards,
First try resetting the program.
http://lata.me.uk/corel/reset/reset.htm
Delete the folder 19.0 from here:-
C:\Users\User Name\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\19.0
(type %appsdata% into windows search box)
If the above does not help....
Can you uninstall using the Cleanup tool from here
http://forum.corel.com/EN/viewtopic.php?f=1&t=59847
After uninstall, delete that 19.0 folder again.
Manually Install video studio from the download folder
\64bit\Ultimate (double click Setup.exe file)
By default downloads go to a VideoStudio folder on the desktop.
Run the program, if ok, install the Standard Content (setup_CHD.exe).
It does take a while on first launch whilst files and libraries are populated.
MDBuc
ram: 16 GB
Post by MDBuc »
Thanks Trevor,
I executed step by step the procedure you proposed and unfortunately it did not solve the issue. I suspect now the content I downloaded since it seems to be made file by file instead having a single zip file with checksum check.
Best Regards,
Marc
Hi Marc
The latest download for the Main CVSX9.5 program is contained in 64bit / Ultimate folder
The Ultimate folder contains 21 separate files/folders. (setup.exe to install)
Otherwise install using the Web Installer that was used to down load the files.
Earlier versions of Video Studio would download a single .exe self extracting file.
MDBuc
ram: 16 GB
Post by MDBuc »
Dear Trevor,
I downloaded again the software. I moved it into a different drive (G:\ref_drivers_softs\20160817_Corel_VideoStudioX9.5). I downloaded it without interruption (in one go).
I cleaned-up the previous installation (as per your procedure)
I re-installed with the "New" distribution.
Conclusion: Same Issue
I though that it does not like starting from a drive which is not c: . So, after the classical clean-up, I started the install from the directory it stores the downloaded files by default (C:\users..), even with the right directory name "VideoStudioX9"
Same issue.
When I mention installation, I mean starting setup.exe from 64bit\Ultimate after removal of roaming data and regular clean-up
The main question is why it does complain and about what?
Just having a look into the evenlog of windows, I have that (exception from vstudio...). oops!! :(
Nom du journal :Application
Source : Application Error
Date : 17/08/2016 22:29:25
ID de l’événement :1000
Catégorie de la tâche :(100)
Niveau : Erreur
Mots clés : Classique
Utilisateur : N/A
Ordinateur : MARC-PC07
Description :
Nom de l’application défaillante vstudio.exe, version : 19.5.0.35, horodatage : 0x57856929
Nom du module défaillant : vstudio.exe, version : 19.5.0.35, horodatage : 0x57856929
Code d’exception : 0xc000041d
Décalage d’erreur : 0x0000000000187a31
ID du processus défaillant : 0x21c0
Heure de début de l’application défaillante : 0x01d1f8c5b28a0bdd
Chemin d’accès de l’application défaillante : C:\Program Files\Corel\Corel VideoStudio X9\vstudio.exe
Chemin d’accès du module défaillant: C:\Program Files\Corel\Corel VideoStudio X9\vstudio.exe
ID de rapport : 037fd08a-6e00-4190-8ca1-7d2e0f3ebde8
Nom complet du package défaillant :
ID de l’application relative au package défaillant :
XML de l’événement :
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2016-08-17T20:29:25.877090200Z" />
<EventRecordID>23929</EventRecordID>
<Channel>Application</Channel>
<Computer>MARC-PC07</Computer>
<Security />
</System>
<EventData>
<Data>vstudio.exe</Data>
<Data>19.5.0.35</Data>
<Data>57856929</Data>
<Data>c000041d</Data>
<Data>0000000000187a31</Data>
<Data>21c0</Data>
<Data>01d1f8c5b28a0bdd</Data>
<Data>C:\Program Files\Corel\Corel VideoStudio X9\vstudio.exe</Data>
<Data>037fd08a-6e00-4190-8ca1-7d2e0f3ebde8</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
Btw, I did not install New Bleue effects..
Best Regards,
Marc,
MDBuc
ram: 16 GB
Post by MDBuc »
Dear all,
I'd like bringing more chronology on the events found in evenlogger:
1)
Source : VSS
Date : 17/08/2016 22:26:48
ID de l’événement :8224
Catégorie de la tâche :Aucun
Niveau : Information
Utilisateur : N/A
Description :
Le service VSS s’arrête, car le délai d’inactivité est dépassé.
<System>
<Provider Name="VSS" />
<EventID Qualifiers="0">8224</EventID>
<Level>4</Level>
<Task>0</Task>
<TimeCreated SystemTime="2016-08-17T20:26:48.740262800Z" />
<EventRecordID>23926</EventRecordID>
<Security />
</System>
<EventData>
<Data>
</Data>
<Binary>2D20436F64653A2020434F525356434330303030303737302D2043616C6C3A2020434F525356434330303030303735322D205049443A202030303030363430382D205449443A202030303030323232342D20434D443A2020433A5C57494E444F57535C73797374656D33325C76737376632E6578652020202D20557365723A204E616D653A204155544F52495445204E545C53797374E86D652C205349443A532D312D352D313820</Binary>
</EventData>
</Event>
2)
Date : 17/08/2016 22:29:22
Niveau : Erreur
Utilisateur : N/A
Description :
Code d’exception : 0xc0000005
ID de rapport : 4efa82f1-2e21-49c1-a740-31d57d4240b1
<System>
<Level>2</Level>
<Task>100</Task>
<TimeCreated SystemTime="2016-08-17T20:29:22.070356300Z" />
<EventRecordID>23927</EventRecordID>
<Security />
</System>
<EventData>
<Data>c0000005</Data>
<Data>21c0</Data>
<Data>4efa82f1-2e21-49c1-a740-31d57d4240b1</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
3)
Source : Windows Error Reporting
Date : 17/08/2016 22:29:23
ID de l’événement :1001
Utilisateur : N/A
Description :
Récipient d’erreurs 120513663992, type 4
Nom d’événement : APPCRASH
Réponse : Non disponible
ID de CAB : 0
Signature du problème :
P1 : vstudio.exe
P2 : 19.5.0.35
P3 : 57856929
P4 : vstudio.exe
P5 : 19.5.0.35
P6 : 57856929
P7 : c0000005
P8 : 0000000000187a31
P9 :
P10 :
Fichiers joints :
C:\Users\Utilisateur\AppData\Local\Temp\WER8612.tmp.WERInternalMetadata.xml
Ces fichiers sont peut-être disponibles ici :
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_vstudio.exe_bf59e9d3a9644040f486798e96f9c78165e387ba_7121007e_24888cb9
Symbole d’analyse :
Nouvelle recherche de la solution : 0
Statut du rapport : 0
Récipient avec hachage : 6dea7734a85a6a50f0a3a71655d2d729
<System>
<Provider Name="Windows Error Reporting" />
<EventID Qualifiers="0">1001</EventID>
<Level>4</Level>
<Task>0</Task>
<TimeCreated SystemTime="2016-08-17T20:29:23.897187100Z" />
<EventRecordID>23928</EventRecordID>
<Security />
</System>
<EventData>
<Data>120513663992</Data>
<Data>4</Data>
<Data>APPCRASH</Data>
<Data>Non disponible</Data>
<Data>0</Data>
<Data>
</Data>
<Data>
</Data>
<Data>
C:\Users\Utilisateur\AppData\Local\Temp\WER8612.tmp.WERInternalMetadata.xml</Data>
<Data>C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_vstudio.exe_bf59e9d3a9644040f486798e96f9c78165e387ba_7121007e_24888cb9</Data>
<Data>
</Data>
<Data>0</Data>
<Data>0</Data>
<Data>6dea7734a85a6a50f0a3a71655d2d729</Data>
</EventData>
</Event>
4)
Niveau : Erreur
Utilisateur : N/A
Description :
<System>
<Level>2</Level>
<Task>100</Task>
<Security />
</System>
<EventData>
<Data>21c0</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
Based on 3), it is an app crash of the appli.
Best Regards,
Marc
Hi Marc
Unfortunately I am at a total loss as to why the program will not launch.
The details you provided do not mean that much to me other than you using the latest fully patched version 19.5.0.35.
I have that running on Windows 10 without problems, although was installed using Windows 7.
I notice the text is French, do you think the program language may be an issue here, French as opposed to English versions.
I assume you have tried right click vstudio.exe and run as Administrator
Disconnect internet connection and try running program, should overcome registration.
As I say I just do not know what else to suggest.
You should contact Corel Support if you have not already done so.
Auz
Alludo
motherboard: Vanilla Build System
processor: Intel Core i7-4790 CPU
ram: 16TB
Video Card: NVIDIA GeForce GTX 750 Ti
Hard_Drive_Capacity: 16TB
Monitor/Display Make & Model: Samsung SyncMaster E2020
Corel programs: SME For WinDVD, VS, Painter
Post by Auz »
Greetings!!
Where true, you can have multiple versions of our software installed, coming from the Level II desk at the technical center, I have found in a lot of cases, having only one version on the system is preferable. I would strongly recommend the following actions:
1) Use the clean up tools to fully remove all versions of Videostudio from your system, up to and including X9.5
2) Ensure when you reinstall X9.5 that you verify that Windows did not attach any compatibility options to the launcher / program executable. (*Righ click on the desktop icon, choose properties, click Compatibility tab and remove any / all check marks*)
3) Ensure Windows is fully up to date by checking Windows Updates
4) Ensure you have the latest drivers for your video and sound card
If you have any further concerns, I invite you to create a support ticket by visiting https://support.corel.com/hc/en-us and ask to be transferred to the Level II team, where either myself or one of my colleagues can work with you to ascertain the problem in real time.
Auz
Corel Technical Support Desk II
Jim Pickles
motherboard: Gigabyte Technology Co B150M-D3H-CF
processor: 3.40 gigahertz Intel Core i7-6700
ram: 8 GB
Video Card: ASUS R7 360 Series
sound_card: AMD High Definition Realtek High Definition Audio
Hard_Drive_Capacity: 2240GB
Monitor/Display Make & Model: DELL 2209WA
Corel programs: VideoStudio X9.5, VideoStudio 2020 Ult
Post by Jim Pickles »
There seems to be a hotfix for this now (released about 2 months ago, according to Norton) which I have used (with a few issues, mentioned elsewhere):
https://support.corel.com/hc/en-us/arti ... esult-100-
Jim.
Thanks Jim for the details of the hotfix.
I have not had a problem but sure those that do will be pleased to have this fix.
pepegota
motherboard: ASUS TUF Z390-Plus
processor: Intel i9 - 9900k
ram: 64 GB
Video Card: GTX 1660 6GB
sound_card: On board sound
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Ben Q, "21" LCD
Corel programs: VS 2018, VS 2019, VS 2020
Post by pepegota »
I have just encountered the same problem. A reinstall solved the problem but, when I applied the 9.5 update the problem came back.
Post by BrianCee »
We seem to have two topics running on the same subject - please continue the discussion here http://forum.corel.com/EN/viewtopic.php?f=1&t=60643 where you will find the solution
locking this topic to prevent more confusion
Locked
