I am new to AfterShotPro (3), I am trying it in Linux OS.
I like it very much, but I have a little problem.
When I'm customize a RAW photo in AfterShot, it looks good, as I would like to look.
But when I export to jpg file, colors are a little bit different on the same monitor. It looks like a little bit more red/magenta, and it doesn't looks good for example on a portrait.
How can I resolve this issue? Could somebody explain it to me?
Wrong colors after export
VChris
- System_Drive: N/A
- motherboard: MSI B85M-G43 MS-7823
- processor: Intel Core i5-4570 CPU 3.20GHz
- Video Card: Radeon HD 5000 6000 7350 8350 Series
- sound_card: Radeon HD 5400 6300 Series
- Hard_Drive_Capacity: 500GB
- Monitor/Display Make & Model: BENQ 24"
- Corel programs: Aftershotpro3
Dutchmm
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
Re: Wrong colors after export
Chris
You will find (in File, Preferences, Color Management) a menu item for your Monitor Profile. If you have calibrated your monitor (you have, haven't you?) against something like the Spyder 2, and installed the profile for every ksh session you run, you can select the resultant profile here. That way you should see the same colours in ASP as in Gwenview etc. At least, I think so. If you are still seeing problems, perhaps you need to select your generated profile for the File, Preferences, Soft Proofing choice.
HTH (and AFX will put me right if I got this wrong)
VChris
- System_Drive: N/A
Huhh, I haven't calibrated my monitor, because I don't know how to do that... Don't be angry with me, but I am not an expert
Could you help me how can I calibrate my monitor, and how can I get a monitor profile??? I don't understand this method at all. Sorry for my poor knowledge.
Important note: I am using Fedora 24 Linux distro
VChris
- System_Drive: N/A
Dutchmm, thank you for your help! I've found the solution
In Gnome Control Center there's a menu item, Color management. And inside this there is my monitor, and clicking on the Details button, it shows me my monitor's icc profile files path. I've found this file, copy to ASP profiles folder, and select it inside ASP's Color management. And that's it, it works!
Thank you very much for your help!
