There is a thread about creating a sketch of a portrait here:
http://forum.corel.com/EN/viewtopic.php?f=56&t=60048
It's easy enough to record a script to do this and get a result close to what the OP was trying to achieve. However, people making a sketch might have different ideas about the best setting for various layer opacities to achieve their particular needs. Would the only way to be able to stop the script after pasting a layer (so as to be able to change the layer opacity before moving to the next step) be to use Gary Barton's Pause script? Or is there another command that would work?
Pausing script to set layer opacity??
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
JoeB
Using PSP 2019 64bit
JoeB
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Pausing script to set layer opacity??
There is no pausing option in scripts.
Gary's pause script takes a very convoluted route to save your position and come back to that position in the script the next time you run it. If you want the user to be able to play non-stop Gary's pause script is the best option.
Another, less attractive option, is to build your own UI with TkInter and let the users adjust the values in the dialog, on every value update you change the opacity of the layer in script. This way the script never actually stops but the user can still change the opacity.
Personally I think Gary's pause script is easier.
JoeB
- ram: 8 GB
Gary's Pause script is definitely easier for me!LeviFiction wrote:There is no pausing option in scripts.
JoeB
JoeB
