Can you run 32bit VS pro X7 on Win 10
Ilene
motherboard: Thimphu intel Z 170
processor: i7-6700K quad core
ram: 16GB DDR4
Video Card: 6GB NVidia GeForce GTX 980Ti
sound_card: envy audio AV - band and olfson 5.1 channel
Hard_Drive_Capacity: 550SSD+
Monitor/Display Make & Model: Dell Ultra Sharp 25" 2560x1440
Corel programs: VSX8 32 And VSX9 64 and VSX10 32
Post by Ilene »
Has anyone tried this? Corel support wasn't sure it would run as X7 was designed for Win 7??
Thinking of going back... Missing my new blue transitions more than any minor updates that Vspro X9 has to offer. Really very little difference...
Would keep X9 and X7 on same machine of it worked. Obviously wouldnt /couldnt open at same time.
Lmk...
Re: Can you run 32bit VS pro X7 on Win 10
Post by BrianCee »
I have Videostudio X4, X6, X7 , X8 , X9 all running on 32bit Windows 10 and I am not aware of any problems with any of them
Ilene
ram: 16GB DDR4
Post by Ilene »
Wow. I thought X9 could only run on 64bit? Good to know! Thanks
Post by BrianCee »
When you first download the installer for X9 it will check your system and download the correct programme - but if you check the updates page for X9 here - - http://www.videostudiopro.com/en/suppor ... sion-tab=0
you will see updates are for 32 and 64 bit programmes
Ilene
ram: 16GB DDR4
Post by Ilene »
So I would download from this link instead of the one i have??
Post by BrianCee »
for updates yes - but unless you downloaded the 32bit programme originally you may not have a 32bit programme to start with
Ilene
ram: 16GB DDR4
Post by Ilene »
Gotcha. My link doesnt indicate so maybe there was a choice when u downloaded. I got a new comouter and the guy i bought it from had set some things up for me including Video Studio.
Maybe im better off keeping x64 ver of 9 and install V7 in 32 bit and use both? Argh. Corel does not make it easy!
Think im gonna buy a monthly to adobe premiere and see how i like it... Lol.
Thank you! This forum is always so helpful!!
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
Ilene wrote:Gotcha. My link doesnt indicate so maybe there was a choice when u downloaded. I got a new comouter and the guy i bought it from had set some things up for me including Video Studio.
Don't blame Corel, your issue is with New Blue, when you open the VSX9 installer, you are given the option to download 32 bit or 64 bit, many of us download both versions.
if you try the Premiere Pro monthly subscription method, you will have a massive learning curve, I have CS5.5 and eventually uninstalled it, just too difficult to navigate around, I do have Premiere Elements installed which I do use, but it is not available on a subscription basis
Ilene
ram: 16GB DDR4
Post by Ilene »
True!!
So i can have both 32 bit abs 64 bit of same version installled?? Obviously can't open at same time...
RobertOZ
Post by RobertOZ »
You can have the 32 bit version of VSX7 and the 64 bit version of VSX9 installed at the same time, you cannot have both 32 bit and 64 bit versions of VSX9 installed
Ilene
ram: 16GB DDR4
Post by Ilene »
Excellent -- keep u posted!!
I should reView the thread on the install of 7 in win 10 w those offending updates.
I assume i will install and then locate those uodates/patches
