Inserting a transition into a line of clips
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
I have lines of jpegs at various points on the timeline.I want to use cross fade in between only these images.Is there a quick way to do this.
canuck
operating_system: Windows 8.1
Re: Inserting a transition into a line of clips
Post by canuck »
Set Crossfade as your default transition in Preferences.
Then simply overlap the photo with the previous phots in the timeline by the amount of duration you want
Hi Kenneth
The various points comment,??????
If you right click the transition in the library there is an option to Apply effect to Video track, not overlay tracks.
This will add transition to all clips, duration as set in Preferences.
Otherwise it’s a manual, one at a time job.
Ken Veal
ram: 32 GB
Post by Ken Veal »
To clarify, in my present project there are instances in the main video track where there a line of say 15 images where I want to apply a crossfade transition but only to them and not all of the video track.At present, I am adding the crossfade manually in between each of these 15 images.In other instances, I apply the transitions manually choosing them as I go. So what I wanted to know was how to apply the crossfade to the 15 images in one "swoop" if that is possible.
Hi Kenneth
There may be a workround.
First set F6 Preferences to your preferred transition and timing (automatic set transition effect)
Also set the Image duration
Place a marker at the beginning of the first image. (A chapter point would do)
Drag all 15 images to the library
Delete / remove the images from the track
Drag images back to timelines marker
All images will be the same duration, all will have the transition applied.
Remove marker.
It works but maybe as easy to drag that transition?
Ken Veal
ram: 32 GB
Post by Ken Veal »
OK,
Thanks for that Trevor, that sounds logical, at least now I have a choice of how to do what I want.
Ken
