Linux x64
today i spent a fair amount of time getting my watermarker script running again.
afx helped a lot.
using imagemagick i finally found the error message:
Code: Select all
convert: /opt/AfterShot3(64-bit)/lib/libgomp.so.1: version `GOMP_4.0' not found (required by /usr/lib/x86_64-linux-gnu/libMagickCore-6.Q16.so.2)i checked this with "readelf -a /opt/AfterShot3(64-bit)/lib/libgomp.so.1.0.0 | grep -i gomp_4" - which comes up empty.
the other libgomp on my system in /usr/lib/x86_64-linux-gnu has the GOMP_4 in it.
workarounds:
- put an "unset LD_LIBRARY_PATH" into any script you call from ASP3. (tested, works, pretty much future proof)
- relink the library to a current version (untested. very likely gets reset with upgrades etc)
cheers,
grubernd
PS: in case anyone wonders. GOMP == GNU Offloading and Multi Processing Runtime Library
