How to UNINSTALL Calendar Checker - or remove from toolbar
tango_jd
Post by tango_jd »
Nasty Nasty trick - dumping some crap on my toolbar when I installed Photo Express.
i dont like the programme anyhow but may use it for little things that my other programs dont do etc.
However - where did Calendar checker come from??
Anyone know how to remove it? All the Google references link to a Ulead page that doesnt exist now.
tango_jd
I HAVE THE ANSWER!!!!!!!
Post by tango_jd »
All the hyperlinks I found on the web point to a non-existent page.
Ulead's reply to me as follows:
[b](A) [/b]
If you create multiple Weekly/Monthly/Yearly calendars to be your
wallpaper, Photo Express will replace the wallpaper automatically. Thus
there is a calendar checker in Photo Express, which checks the dates of
the system, and you don't need to change the wallpaper manually.
To remove calendar checker,please follow the steps below:
1. Click the Start button, then select Settings: ""Taskbar & Start
Menu"".
2. In the dialog box, click Start Menu Programs Tab and click the Remove
button.
3. In the ""Start up"" folder, find the ""Photo Express calendar
checker"" option and click the Remove button.
[b](B)[/b][b]To remove it properly,[/b] try the steps below:
1. Go to Start > Run. On Open, type msconfig then click ok. This will
open the System Configuration Utility.
2. Select the tab of Startup and locate Ulead Calendar Checker.
3. Remove the check mark on Ulead Calendar Checker by clicking on it
then click Appy and OK. You will then be prompted to restart your
computer.
4. After restarting your computer, go to Start > Settings > Taskbar &
Start Menu.
5. Select the tab of Advanced then click the Remove button.
6. Locate Disabled Startup Items and double click on it.
7. Highlight/select Ulead Calendar Checker then click the Delete button
This should then remove the Calendar Checker from your startup. Please
email us again if you have any questions and if you were able to remove
it.
Thank you and good luck!
tango_jd
Re: How to UNINSTALL Calendar Checker - or remove from toolb
Post by tango_jd »
[quote="tango_jd"]Nasty Nasty trick - dumping some crap on my toolbar when I installed Photo Express.
Thanks[/quote]
WELL I TRIED THESE - and NO JOY.
SO - I uninstalled the LOT and hey presto! I am free of the the intrusive Toolbar calendar checker thingy........will I miss it?? NO!
pasky
How to remove the calendar checker.
Post by pasky »
Hello!
I just want to share some workarounds on how to remove the calendar checker. You may try the following steps:
1. Go to Start > Run. On Open, type msconfig then click ok. This will open the System Configuration Utility.
3. Remove the check mark on Ulead Calendar Checker by clicking on it then click Apply and OK. You will then be prompted to restart your computer.
4. After restarting your computer, go to Start > Settings > Taskbar & Start Menu.
This should then remove the Calendar Checker from your startup. I hope this will work with you.
Good luck :roll: [/url]
rsc
Post by rsc »
The only way I found to kill it dead was to go to registry and remove it from the local machine software microsoft windows run section. Finding "calcheck" gives that on about the third or fourth search section.
